09-26-2012, 08:32 PM | #1 |
Pebble Pounder Join Date: Jun 2011 Location: Sonoma, Ca
| 3racing winch suggestions
Hi, i just bought the 3racing winch and I noticed how you ahve to use a battery to power it. Has anyone modifies there's so that it goes straight to the reciever and gets power from the Primary ESC? If possible pictures would be helpful. thanks |
09-26-2012, 09:28 PM | #2 |
Rock Crawler Join Date: Mar 2011 Location: hampton
| Re: 3racing winch suggestions
just solder the input leads to the battery plug on your esc
09-26-2012, 10:09 PM | #3 |
I wanna be Dave Join Date: Jun 2007 Location: Arlington wa
| Re: 3racing winch suggestions |
09-26-2012, 10:16 PM | #4 |
Rock Crawler Join Date: Oct 2009 Location: Washington State
Blakeski is right. They don't recommend high voltages. That being said, I have been running mine directly off of my 3S battery plugs for two years now. So go figure... If you're real worried about it, you can also run the power leads to an external BEC. Last edited by Pointman; 09-26-2012 at 10:20 PM. |
09-26-2012, 10:24 PM | #5 |
I run mine through the rx, I also power my rx at 8.4 threw my BEC though.
09-27-2012, 12:07 AM | #6 |
So what should i solder the winch power plugs too, my esc's wires are way to big withe bec pro too, to fit more wires on to it. Is there a way to run it though your RX, and what do you have to modify to do that? |
09-27-2012, 05:11 AM | #7 | |
| Re: 3racing winch suggestions Quote:
Keep in mind, some RX's DON'T like high voltage, so running the voltage up on a BEC may hurt the RX. Keep the voltages down and the winch may feel weak. Since it looks like you have a CC BEC Pro, I would do a splitter on the output. Plug your servo into 1 connector & the winch into the other connector. | |
09-27-2012, 08:06 AM | #8 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
Running through the RX is great for simple wiring, but I don't like putting the load through the receiver. You should really just tap off the battery line or an exBEC as others have suggested.
3racing winch suggestions - Similar Threads | ||||
Who sells Warn winch decals for 3racing winch? | Wild Snapper | Scale Accessories | 6 | 12-03-2009 06:38 PM |
