11-17-2012, 04:00 PM | #1 |
Pebble Pounder Join Date: Aug 2011 Location: phoenix (Ahwatukee)
| Stock bevel gears on wraith/ dingo?
According to the axial website, both the dingo and the wraith have 38/13 bevel gears. However, I don't believe this to be the case. I can tell the scx-10 does not have the same gear ratio as my wraith. Anyone know what is actually in them?
11-17-2012, 04:35 PM | #2 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
| Re: Stock bevel gears on wraith/ dingo?
Well are they both stock rtr rigs? if thats the case then dingo has a 27t motor compared to wraiths 20t motor
11-17-2012, 04:42 PM | #3 |
yes, I just looked at my wraith it does have the 38/13. Still not sure on the scx-10. my wraith has a 27t and so does my scx-10 and the scx-10 seems way to fast, even though they have the same pinion/ spur. I guess I'll have to open up the axle.
11-17-2012, 06:36 PM | #4 |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
| Re: Stock bevel gears on wraith/ dingo? It has to do with tire size, bigger tires will give you more speed, smaller tires less speed.
11-17-2012, 07:04 PM | #5 |
| Re: Stock bevel gears on wraith/ dingo? |
11-17-2012, 07:20 PM | #6 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
11-17-2012, 07:27 PM | #7 |
11-17-2012, 08:14 PM | #8 |
All axial rigs with the exception of the xr have the same bevel gears. The wraith being faster can be attributed to larger tires and different spur/pinion gear ratios. |
11-20-2012, 07:26 PM | #9 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
The wraith has 80/20 pinion/spur, the dingo has 87/14 gearing stock. The scx/wraith use the EXACT same ring & pinions. The wraith is heavier so even with smaller tires the scx might be close to the same speed as a stock wraith. Also the condition of the motors and the esc settings might not be the same which could cause a difference
Stock bevel gears on wraith/ dingo? - Similar Threads | ||||
Axial HD Bevel Gears back in stock! | RPP Hobby | RPP Hobby | 2 | 10-12-2012 02:04 PM |
bevel gears | Georgerm | Tamiya TLT Crawlers | 3 | 12-08-2009 08:50 AM |
Bevel gears? | Bad_Habit | Tamiya Txt-1 and Juggernaut | 12 | 07-15-2007 08:32 PM |
