09-06-2006, 06:54 PM | #1 |
Newbie Join Date: Jul 2006 Location: Guadalajara
| Lost front traction
I have tree 1:6 nylint Jeeps, one of them are losing front traccion, it stucks easily, the rear traction is working normally but front is not well. What can I do ? Last edited by GuAnAtoS; 09-06-2006 at 07:18 PM. |
09-06-2006, 06:56 PM | #2 |
RCC Addict Join Date: May 2006 Location: Aroostook county
Umm, you can rephrase that so i can read it, and maybe ur belts are slipping
09-06-2006, 07:01 PM | #3 |
One of my 1:6 are losing front traction, , Probably the belts are slipping but if is it how fix it?
09-06-2006, 11:17 PM | #4 |
Newbie Join Date: Aug 2006 Location: So. IL
| open it up and clean it. if you have some belt dressing use it, really helped mine. apply it with your fingers so there's no over spray or drips, helps keep the insides cleaner that much more .
09-07-2006, 08:16 AM | #5 |
Quarry Creeper Join Date: Apr 2006 Location: Pittsburgh
I would replace the front belt with the O-ring mod listed in the stickies at the top of the 1:6 Nylint forum.
09-08-2006, 06:11 AM | #6 |
Rock Stacker Join Date: Jun 2006 Location: Balto.
| Hmmm
Funny, it wasn't until I did the o-ring mod that mine started slipping. Plus I've had a HELL of a time getting the hi/lo mechanism to work right again; the lever won't hit the microswitch to stop the hi/lo motor! I put some oil in the gear boxes and it may have spilled on the belt, I guess. If he means what I think he means the front wheels turn but you can grab one with your hand and it stops, even thought the motor is still running.
09-11-2006, 05:41 PM | #7 |
Let me try all your sug. tnx |
