Thread: Worm and Worm Gear Question
Old 07-13-2013, 10:29 PM   #1
Pullman Crawler
A_Jeeper's Avatar
Default Worm and Worm Gear Question
Okay guys, I'm in the middle of my TJ Build and I want to make up a working Steering gear (Steering box). Something that will be to "scale". I would like it to be ran from the steering column and really turn the wheels. My plan is to have a servo under the dash the will be running the steering column. I am having a hard time finding a set of gears that will work for it. I need a hardened steel Worm and Worm gear set that will be the base to build the box around. My problem i am having is it is hard to find a set of gears small enough and when i do find some, they are out of stock. I was hoping that some of you guys know some site that i don't that have something that will work.
This is the best I can find, but the worm is still bigger then i would like.
http://sdp-si.com/ss/pdf/81001213.pdf
What do you guys think? any Ideas?
Thanks for whatever help you can give.
A_Jeeper is offline   Reply With Quote
Old 07-13-2013, 11:57 PM   #2
Default Re: Worm and Worm Gear Question
I've been thinking about this too for a Jeep tuber I'm working on for my stepson. But I'm not sure where to find gears or how feasible it really is. Might be better to just use a bell crank.
JBailey is offline   Reply With Quote
Old 07-16-2013, 12:43 AM   #3
Losi Micro Trail Trekkers use a brass gear and steel worm. These are probably small enough to accomplish your task but still strong enough for what you need. IIRC they're 16:1 ratio or pretty close too so you'll get quicker steering than even the best ratio of the gears you posted.
DrewHammer is offline   Reply With Quote
Old 07-16-2013, 02:39 AM   #4
This should solve your requirement...
I think this company is the best when it comes to availability of small gears....
But Horrible price
HPC Gears Home page
wings_of_fire is offline   Reply With Quote
Old 07-18-2013, 08:40 AM   #5
Pullman Crawler
A_Jeeper's Avatar
Thanks for the information guys I will take a look.
Worm and Worm Gear Question - Similar Threads
HD Worm gear issues...Still?? maxxflip Team Losi Comp Crawler 25 04-06-2013 05:46 PM
worm gear?? ontriocrawler Team Losi Comp Crawler 8 04-01-2011 04:49 PM
New worm gear question Creepy Crawler Team Losi Comp Crawler 23 11-03-2009 10:34 PM
worm gear Skyjacker56 General Crawlers 4 12-01-2008 06:12 PM
