07-05-2013, 09:53 PM | #1 |
RCC Addict Join Date: Oct 2012 Location: Norcal
| RC4WD AX2 2 Speed Transmission.
Does anybody know if the AX2 has aluminum or steel internal gears? Thanks... |
07-05-2013, 10:17 PM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
| Re: RC4WD AX2 2 Speed Transmission. |
07-06-2013, 12:26 AM | #3 |
That really does not answer my ?
07-06-2013, 12:32 AM | #4 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
Yes it does. I would suggest if you are going to run any kind of power through it to get the updated shaft for it.
07-06-2013, 03:50 AM | #5 |
Rock Crawler Join Date: Jan 2007 Location: UK
Steel gears
07-06-2013, 06:35 AM | #6 |
Thanks, question answered.
07-06-2013, 07:58 AM | #7 |
You need to read. I did the searching for you. At the bottom of that post it says HARDENED STEEL GEARS. There are pictures in that thread of the internals even. This is a forum you have to read just a little bit.
RC4WD AX2 2 Speed Transmission. - Similar Threads | ||||
Rc4wd ax2 2 speed bearing's | Jacksprogis | General Crawlers | 11 | 12-13-2012 02:59 PM |
