07-06-2013, 08:31 PM | #1 |
Newbie Join Date: Sep 2009 Location: Lakewood, CO
| Winch hook removal?
Is there a trick to removing the stock hook from the rc4wd winch? I see a pin but it doesn't seem to come out. Are you supposed to bend the pin straight? Thanks in advance for your help. |
07-07-2013, 06:52 AM | #2 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Winch hook removal?
Should be a small wire on one side..... Pull that and push pin out. May need to punch it out with a smaller pin.
07-07-2013, 08:12 AM | #3 |
Rock Crawler Join Date: Oct 2012 Location: Casper
The cotter pin will likely break when you straighten it, so if you plan to re-use the same hook, make sure to have a new cotter pin.
07-10-2013, 06:43 PM | #4 |
Thanks for the input. I didn't see or think of the obvious. Since I'm changing the line, I could just cut the old wire off. My 43 year old brain just doesn't work like it used to. Thanks again for your input. |
Winch hook removal? - Similar Threads | ||||
Scale Winch Hook & Winch Line giveaway! | Locked Up | General Crawlers | 69 | 01-20-2013 10:53 PM |
Winch hook-up help | Steve at Danfor | Axial SCX-10 | 7 | 07-05-2009 06:26 PM |
