01-18-2005, 02:25 PM | #1 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
| can someone make this for me.
i want to use 2 gd-600's for a crawler but i dont know how to set them up, so can someone build them fo me? sorry i dont have a picture or ne thing, but basicly i want a motor (would a stock titan work fine for a 2.2 crawler?) hooked to a gd-600. then that drives a shaft to another gd-600 which acts as a geared down transfer case i would be really happy and would pay someone that could modify the 2 gd-600's to do this if i draw this in paint, how would i get it on this board? just like any other picture? |
01-18-2005, 02:27 PM | #2 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| Re: can someone make this for me.
a Titan motor will only run half speed on 1 battery..that motor is intended for 14.4 volts..
01-18-2005, 02:37 PM | #3 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
Can you explain to me why you think you need 2 gd600's hooked up together?
01-18-2005, 03:40 PM | #4 |
Quarry Creeper Join Date: Jul 2004 Location: Texas!
I'm thinking that he wants the gd600 to be like a tranny... I dont no how that would work though.... Just get a stampede tranny if you meant having the gd600 for a tranny.
01-18-2005, 04:59 PM | #5 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
No I think he literally wants a motor driving one GD600, which drives another GD600 which then drives the tranny. Why would you ever want that much reduction/effort in a 2.2 crawler? Get a lathe motor and if thats not enough get a GD600. |
01-18-2005, 05:11 PM | #6 | |
| Re: can someone make this for me. Quote:
01-18-2005, 05:50 PM | #7 |
Quarry Creeper Join Date: Oct 2004 Location: vegas
will lathe motors fit in a vmg? can some one give me a link and picture size next to a vmg motor and where the screw are? thanks
01-18-2005, 06:04 PM | #8 | |
i want the motor to drive one gd600, then it drives the next gd600 with a shaft, then the second one drives the axles maybe this will make sense ok, the motor turns a gear on the end of its shaft that gear turns the big gear in the gd 600 the big gear in the gd600 turns a maxx shaft the maxx shaft turns a small gear in the second gd600 the small gear in the second gd600 drives a big gear in the 2ng gd 600 that gear turns a maxx shaft to the front and one to the back axles does that make any sense at all???! that is as simple as i can make it without a drawing | |
01-18-2005, 06:10 PM | #9 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
The 'GD tranny' would still only have one output shaft. Unless you want your TLT to be 2wd, you would need a transfer case. The Graz has a transfer case, thats how it works. He just used 2 GD's for more reduction, not as a full blown tranny. |
01-18-2005, 06:17 PM | #10 | |
01-18-2005, 07:26 PM | #11 |
Rock Crawler Join Date: Dec 2004 Location: Land of the Free, because of the Brave
Spooky, I'm a machinist and yes it can be made. But in my opinion, the cost of design and materials would far outweight any benefits that you would gain from this type of setup. Again, just my opinion. |
01-18-2005, 11:54 PM | #12 | |
BUT.. since you never had the chance to see that rig in action, you would have seen that the idea was good, the function failed. The two GD's hooked together just didn't work due to the ability of the GD's to flex and move. Ryan also had issues with his German made/imported transfer case.... That rig is no longer... I think the idea behind two GD's hooked together is a bad one... not only will it be a BIG combo(length, aka size wise) but you'll have to blend the two units together as one to stop any flex or seperation of the two gearboxes. This means you'll need to fab up a solid housing....... by the time you finish the fab work, spending the money and all the time to build a solid unit you could have purchased a couple of Maxx trannies, few 'Pede trannies and money on beer to feed the after work backyard crawling time. Go get a tranny that doesn't need much thought.... Just my .02 worth. | |
01-19-2005, 08:04 AM | #13 | ||
this makes a lot of sense why not to do it, but would it still have the same problems with them not hooked together and not having a german imported transfer case like he had? the reason i wanted to do this is so i could have the motor in the back and the transfer case in the middle, instead of having the whole tranny/transfer case,and motor in the middle. does anyone have any other (cheap) ideas of how to do this? i could probably build my own transfercase, but i dont know what i would use for a tranny. | ||
01-19-2005, 10:46 AM | #14 |
Pebble Pounder Join Date: Jul 2004 Location: Quakertown PA
I've had the same idea as far as seperating the motor from the trans. I'm going to build my own trans/transfer case. Although if I can make the trans small enough I might just keep the motor attached to it. Check out www.sdp-si.com for all kinds of drive components for a custom tcase. Couldnt you use a Pede tranny with the GD600 bolted to it, put the motor where you want it, and run a slider from the motor to the GD600? Eric |
01-19-2005, 09:23 PM | #15 |
Or skip all this thought process and spend some money..... 3 speeds and real transfer case.... Hua can hook you up! |
