08-27-2013, 02:02 AM | #1 |
Newbie Join Date: May 2013 Location: Canada
| Vanquish Gear Guard
Hey can anyone help me with the following problem? When I mount my gear guard on my Vanquish transmission the screws stick out too far. Thanks |
08-27-2013, 04:14 AM | #2 |
Rock Crawler Join Date: Sep 2010 Location: Keego Harbor, MI.
| Re: Vanquish Gear Guard
Your Missing the 7.4mm spacers and center collar/spacer Do you have them ? Regards Rick |
08-27-2013, 09:21 AM | #3 |
08-27-2013, 10:08 AM | #4 |
| Re: Vanquish Gear Guard |
08-27-2013, 11:01 AM | #5 |
Rock Crawler Join Date: May 2012 Location: Columbus
or cut PVC tube to match it
08-27-2013, 11:03 AM | #6 |
| Re: Vanquish Gear Guard The gear guard only includes that spacer because before it came out the only Axial transmissions available all included the spacers. Now they are molded into the rear of the spur gear cover that comes with all the transmissions.
08-27-2013, 11:52 AM | #7 |
Thanks for the info. Maybe someone here can help me with my other problem. What screws do I use to mount the Vanquish transmission housing to the base. The four screws that held the axial housing appear to have a coarse thread designed for plastic. |
08-27-2013, 11:57 AM | #8 |
You need some M3 flathead screws.
08-27-2013, 12:31 PM | #9 |
PM me your address and i'll send you what you need Regards Rick |
08-27-2013, 01:54 PM | #10 |
I joined the Band! Join Date: Aug 2013 Location: The Hills Of VA
I used an aluminum spacer under the head to shorten the bolt..Your going to need a 4mm spacer between the plate and trans if your mounting it that way.
08-27-2013, 03:31 PM | #11 |
08-27-2013, 03:31 PM | #12 |
| Re: Vanquish Gear Guard 30mm I'll send you a real motor plate and hardware but your in BC Will take up to 3 weeks to get to you You pay shipping $18.00 or so............. LMK Regards Rick Last edited by v84x4; 08-27-2013 at 03:35 PM. |
08-27-2013, 03:59 PM | #13 |
The axial manual days the original 4 screws are M3x12mm (AXA466). These are the four screws that hold the transmission housing to the large bottom brace. Should I be looking at M3x12mm (AXIA146) flat head screws (non tapping)? |
08-27-2013, 06:16 PM | #14 |
the 30mm we are talking about is for the Front mounted moter plate like BWD's or Supershafty's I'm not sure what stock Plate screws are I will disassemble a stock trans and let you know unless some on here has that measurement handy Regards Rick |
Vanquish Gear Guard - Similar Threads | ||||
spur gear cover/guard? | axialnut | Axial SCX-10 | 2 | 02-22-2011 08:40 AM |
