11-18-2013, 06:27 PM | #1 |
Rock Stacker Join Date: Aug 2013 Location: Salina
| Difference in Axials Wraith kits??
I have been looking at getting a Axial Wraith, but have looked at the RTR versions and the Builders Kit. I know the cosmetic differences, as far as bodys go and wheels and tires. But is one lower than the rest of them? I keep seeing pictures from axial of the poison Spyder edition sitting next to a Builders kit. The Poison Spyder to me looks to sit lower outta the box than the kit truck or the other RTR version. Am I seeing things, or does one Wraith sit lower than the other two versions? Any and all views is appreciated, and thanks! |
11-18-2013, 06:38 PM | #2 |
Rock Stacker Join Date: Sep 2013 Location: NW arkansas
It does sit lower then the other ones. It has softer springs as well as the shock mounts already beinf flipped Sent from my SAMSUNG-SGH-I747 using Tapatalk |
11-19-2013, 09:08 PM | #3 |
| Re: Difference in Axials Wraith kits??
I was hoping I wasnt seeing it wrong. Id seen the original rtr wraith and its fairly high up, and so is the builders kit. But when I saw the newer poison spyder version I just thought that is seemed lower. I appreciate the help, and am glad to know I wasnt seeing things skewwed funnily.
11-22-2013, 08:59 PM | #4 |
Quarry Creeper Join Date: Jul 2011 Location: Sullivan
with the kits you get some better parts also vs the stock RTR version the kit has better tires with the R35 compound. it has aluminum lower links, better driveshafts and a few other odds and ends. the stock elect on the RTR version are pretty weak also so it won't be long till your replacing servo and motor for me the kits are the way to go. plus you get the fun of building them so you will know about how it all works so when you run into a problem you have a decent idea of what's going on already |
Difference in Axials Wraith kits?? - Similar Threads | ||||
Difference between regular Wraith and poison spyder ? | merin_83 | Axial Wraith | 21 | 08-18-2014 01:30 PM |
difference between ax10 and wraith axles | phre0n | Axial Wraith | 7 | 11-20-2011 01:30 PM |
