11-01-2006, 11:27 PM | #1 |
Quarry Creeper Join Date: Sep 2006 Location: Ithaca, NY
| Modifiying drive pulleys
A common problem with the plastic drive pulleys is that they are two pieces that simply have a peened via heat way of joining the two halves together. After a time they start to seperate which lends itself to making for not only an unstable component, but as they seperate from the play in the three points where they are joined together the pulley actually becomes a "smaller" diameter and leads to the belt(s) slipping here is a fix with pix................. !. Drill out the plastic attachment points one at a time with a 1/8th inch drill. 2. After drilling out just ONE.........insert a 1/8th inch X 1/4 inch long aluminum rivet with a backing washer. Then move on to the next one and repeat........... 3. What ever excess of the rivet that is remaining grind off so it will no impede the pulley from spinning unobstructed. 4. Done.................. Hope this is helpful to others...............Kerry Attached Images kerrywittigView Public ProfileSend a private message to kerrywittigSend email to kerrywittigFind More Posts by kerrywittigAdd kerrywittig to Your Buddy List 10-27-2006, 08:56 PM #6 kerrywittig vbmenu_register("postmenu_455296", true); Newbie Part 2 Attached Images __________________ New to the RC Crawling world! |
11-02-2006, 06:42 AM | #2 |
RCC Addict Join Date: Dec 2005 Location: Beaver Falls
That's a great fix. Wouldn't super glue-ing them back together work?
11-02-2006, 10:39 AM | #3 |
Rock Crawler Join Date: Mar 2006 Location: Dayton
it is a great fix -Dalton |
12-22-2006, 01:00 AM | #4 |
Newbie Join Date: Nov 2006 Location: West Covina, CA 91792
I super glued mine and they've held just fine.
12-25-2006, 03:15 PM | #5 |
Newbie Join Date: Dec 2006 Location: everett
i thinnk that super glue would work just fine
04-28-2007, 08:16 AM | #6 |
Newbie Join Date: Jul 2006 Location: Denver
yep, try super glue, it worked on mine when I did the o-ring mod.
