03-20-2014, 07:28 AM | #1 |
Pebble Pounder Join Date: Feb 2013 Location: Mid Missouri
| Pro Line Powerstroke lighter spring option?
Looking for a lighter rear Powerstroke secondary spring option. Looking for something with a rate of about 2.0-2.2, for rear slash shocks, so ideal length is 58mm, but I'm sure 55-60mm could work. I apologize if this is something simple, I may just not have the proper vocabulary to search it out. Google lands me a thousand links to the spring kits. (Which I already have) |
03-20-2014, 08:19 AM | #2 |
| Re: Pro Line Powerstroke lighter spring option?
Axial SCX springs fit the Proline shocks and they have several spring rates to choose from. I searched "Axial SCX Spring" on Amain but several stores carry them. Will get you started with the part numbers. Products Matching axial scx spring - A Main Hobbies Edit, I see you said you run the Slash Powerstrokes, not sure if the SCX springs fit that model of powerstroke. .. Last edited by Szczerba; 03-20-2014 at 08:22 AM. |
03-20-2014, 09:14 AM | #3 |
Rock Crawler Join Date: Jul 2005 Location: Spartanburg
The SCX springs do not fit the slash version of the PL shocks. I am running the blue rear springs in the front with no "helper" spring. For the rear I am running blue as well. The springs in the rear are a bit short so I am going to have to do some research there. I also drilled the pistons out on them and dropped to 15wt oil. |
03-20-2014, 09:20 AM | #4 |
I'm trying to keep the dual rate (hence the ~60mm length), I'm just a tad too stiff on the secondary (long) spring still. On a scaler, with realistic mounting, so trying to make best possible use out of limited travel.
03-21-2014, 03:35 AM | #5 |
So you are looking for the longer of the two springs in a dual rate setup? If so, I'm pretty sure Losi or AE springs may fit, and they typically have a pretty wide range of available spring rates. You'd most likely need some buggy front springs as most buggy rears would likely be too long. |
03-21-2014, 06:24 AM | #6 |
Thank you very much, that gave me search terms which led me to this: http://www.petitrc.com/reglages/BuggyBigBoreSpring.pdf (More listings in PDF than image) I don't have the full dimensions on what I'm looking for, but I can't imagine it not being in that list. |
03-21-2014, 10:54 AM | #7 | |
| Re: Pro Line Powerstroke lighter spring option? Quote:
Now THAT's what I call a spring chart! | |
Pro Line Powerstroke lighter spring option? - Similar Threads | ||||
Pro-Line Powerstroke top mount? | MetalNut | Axial Wraith | 8 | 01-30-2013 05:57 AM |
