06-26-2014, 05:40 AM | #1 |
Quarry Creeper Join Date: Dec 2013 Location: NoVa
| AR60 front hub slop
So I have this highly modified Deadbolt ax10 with sloppy front hubs. The front axle is composed of an Rc4wd ar60 aluminum axle housing, locked up rc spool, vanquish clamping C-hubs, Strc knuckles, rc4wd cvd axles and dlux bushings. The problem is, when the wheel & tires are on, the slop is too much. If you grab hold of the tire, you can rock it back n forth. It seems to be the axle is loose through the knuckle bearings. The bearings are fast eddy's. Any ideas on how to lessen this issue? thanks CG3 |
06-26-2014, 07:35 AM | #2 |
Rock Crawler Join Date: May 2010 Location: Bedford Ky
Sounds like your bearings are loose in the knuckle. Or the cvd to bearing tolerances are off.
06-26-2014, 08:12 AM | #3 |
| Re: AR60 front hub slop
You need to find the slop first before you can fix it. Pin point where it is. If the slop is in the bearings, you can put some loc tite on the bearing and it will cure all that slop. |
AR60 front hub slop - Similar Threads | ||||
Front axle slop | Rooney7783 | Losi Mini-Rock Crawler | 4 | 01-22-2012 07:53 PM |
Axial hex + VP hub = slop | BurnLatex | Axial XR10 | 13 | 01-28-2011 10:34 PM |
front wheel slop | stelerzman | Axial AX-10 Scorpion | 3 | 10-24-2009 07:31 PM |
