06-28-2014, 09:57 AM | #1 |
Newbie Join Date: Mar 2014 Location: crystal river
| Gearing ?
Here's the deal I'm running a truck that was hand built using e-maxx 2speed trans with 13 tooth pinion 66 spur wraith axles motor is Novak 55 an esc is Novak rooster crawler in low gear it's a ok I feel like it needs lower gear doesn't have a lot of grunt an I can't use high gear unless flat ground should I change motor to different brand or go lower gearing an if so what gears
06-29-2014, 02:50 PM | #2 |
| Re: Gearing ?
1. What's the total gearing motor to wheel? 2. Which wheels and tires do you use? 3. What battery voltage do you use? A 55T motor can handle higher gearing than a lower wind motor, since it has more torque. It's got less power though, so it takes more voltage if you want to go fast. |
06-29-2014, 06:36 PM | #3 |
| Re: Gearing ?
7cell nickle metal 8.4v I think I'm running swamped tsls an just plastic wheels
06-29-2014, 08:06 PM | #4 |
| Re: Gearing ?
If you just want to run what you have, and are OK with a low top speed than you can get away with running a much smaller pinion gear. If you want more snap and a wider usable RPM range then you'll want a lower turn motor, or more voltage. |
07-04-2014, 07:49 PM | #5 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
| Re: Gearing ?
Depends on battery as stated above..hmm if going for torque go for a 15/84t setup or speed then go higher but watch those temps or you'll ruin the motor.
Gearing ? - Similar Threads | ||||
4.0 vs 3.29 gearing. | evan03 | Formula Offroad | 2 | 01-15-2013 01:10 PM |
Gearing?? | Big Daddy | Axial SCX-10 | 14 | 11-27-2011 07:12 PM |
Gearing ?'s | FruitaCrawler | Axial SCX-10 | 1 | 01-22-2010 09:30 PM |
i need some gearing help. | Dubs Chops | General Crawlers | 3 | 12-24-2008 10:37 AM |
gearing ??? | Z-Rider | Tamiya TLT Crawlers | 9 | 01-19-2007 11:40 AM |
