11-23-2006, 10:09 AM | #1 |
RCC Addict Join Date: Dec 2004 Location: Central NY
| Electric NOS
The other night I was bored and figured why not. I had all the stuff laying around and thought I might as well put it to use. First I'm going to try just one cell, and maybe go to two cells. All I did was zip tie a cell to a mini servo, Hitec HS-225BB to be exact, and made it so the servo is basically the switch. I have a wire coming from the positive side of that cell sticking up, and a wire on the servo horn to close the circuit when the swtich is flipped on the radio. I'm going to wire it in a series, as I've already got the max cells the Moped can handle. Ok, pics: First pic: Open circuit Second pic: Closed circuit Third Pic: Gives an idea of the size in the palm of my hand |
11-23-2006, 10:11 AM | #2 |
Rock Crawler Join Date: Jan 2006 Location: In the basement
Interesting idea, I imagine after a while you would lose contact with the wires though.
11-23-2006, 10:14 AM | #3 |
neat but wouldnt just adding it to the pack be lighter? (ie no need for the servo)
11-23-2006, 10:14 AM | #4 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
I see, flip the switch and an extra cell comes into a circuit?
11-23-2006, 10:17 AM | #5 |
Yup.
11-23-2006, 12:05 PM | #6 |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
| So how are you going to go about 'adding' it to the vehicle? What I mean is; If you're adding that to be a boost for the pack that's already there, it has to be added in-line with that pack. But if the servo 'circuit' is 'off', the whole complete battery circuit is incomplete, that is untill the added cell is 'turned on'. I guess I don't see how that'll work. Adding the cell to the pack would be better. I have virtually the same thing going with all my rigs... If I don't need all the power of the pack, I drive with 3/4, 7/8 throttle, then get my 'boost' by pulling the trigger a little more. |
11-23-2006, 02:25 PM | #7 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
He's right. What you need to do is wire up a DPDT toggle switch and have it wired so one side is the regular pack, and the other side is the +1 pack
11-23-2006, 02:29 PM | #8 |
ESC can only handle 7 cells. I already have 7 cells in the pack. This is wired in series to the other pack.
11-23-2006, 02:33 PM | #9 |
Release your anger.. Join Date: Oct 2006 Location: North American Union
interesting, have you tested it yet? |
11-23-2006, 05:13 PM | #10 |
Yeah. My ESC doesn't like the extra power. I engaged it, and it just shuts off.
11-23-2006, 05:37 PM | #11 | |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
11-23-2006, 05:44 PM | #12 | |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
11-23-2006, 05:47 PM | #13 | ||
11-23-2006, 05:52 PM | #14 | |
11-23-2006, 06:00 PM | #15 |
If that's the case, It won't give you any boost. Maybe run time, but with 1 cell paralleled to 7, don't expect much if anything.
11-23-2006, 06:05 PM | #16 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Most of the switches I use have 3 connections. At any time two of the three are closed. You could wire that battery into the circuit using a switch that would allow you to run 6 cells then flip the switch and run seven cells. A lot of trouble though...especially when a little trigger management will work much better. |
11-23-2006, 09:35 PM | #17 |
Newbie Join Date: Feb 2006 Location: West salem
I see something like this about every couple months over at my forum. For amusement purposes I keep lists of them. i always wonder why someone would take a nice proportional throttle and add some rube goldberg contraption to make it "better".. Using the servo to "tweak" the timing on the motor can would be my #1.. I could go on and on about this stuff, I find it entertaining. |
11-23-2006, 09:59 PM | #18 |
Well, the tabs are all broke on this servo, so it could never be mounted. Plus, this is just a blow some time type of thing. Something for fun.
11-23-2006, 11:16 PM | #19 |
I agree,learn to use the throttle better and you'll have your so called "boost" You can also just add a tooth or two to the pinion size for even better "boost" |
11-24-2006, 06:12 AM | #20 | |
