12-12-2006, 08:24 PM | #1 |
Rock Stacker Join Date: Jan 2006 Location: lost
| Strobe Light Install Strobe light install Items needed 2 Strobe lights $5.99 each at pet supplies plus or some pet stores. They go on the dog collar to watch the dog at night Phillips screwdriver Drill bits: 3/8, last 1/4, second, 9/16 first Cordless drill or Dremal tool Wood with a groove big enough to hold the headlight bucket Hot glue gun (mine came from the dollar store) Hobby knife or pocket knife 1) Unbolt the body and flip upside down 2) Remove the headlight bucket with a Phillips screwdriver (don't loose the headlight lens). 3) Set the headlight bucket in the grove facing up set aside the lens 4) Using the Dremal or drill start with smallest drill size above go slow and drill into the center of the bucket 5) Keep enlarging hole with next size bit until you get to the 3/8 bit 6) Remove the clasp and ring from the strobe 7) using a hobby knife or pocket knife trim the hole so strobe light pushes through tight don’t make the hole to big Once the strobe is in place firmly reassemble the lens into the headlight bucket. 9) Now reinstall the headlight bucket assembly back into the Jeep 10) Push the strobe into lens till flush, turn on the strobe with a twist in the back 11) If all went well dab a little bit of hot glue out side the bucket where the strobe passes thru You’re done pics Now this is a finger light I found at the dollar store small enough to do the same thing to the headlight bucket, well any other ideas? |
12-12-2006, 08:26 PM | #2 |
Rock Crawler Join Date: Jun 2006 Location: huh?
Seems Easy Enough I Might Try It
12-12-2006, 09:11 PM | #3 |
RCC Addict Join Date: Sep 2005 Location: Lehi
| Very nice...I am definetely trying that out on my 1/6th! Great job!
