05-28-2015, 06:01 AM | #1 |
Rock Crawler Join Date: Jan 2013 Location: Australia
| Tips for gear adjustment?
Hi everyone, one of the most frustrating and difficult task for me is adjusting the pinion and spur gear to run smoothly. After replacing the motor in both my trucks, the gears haven't run as smoothly since and i was hoping for some tips or something to get them running smooth again. Cheers. Last edited by Hammer!; 05-28-2015 at 06:26 AM. |
05-28-2015, 07:18 AM | #2 |
| Re: Tips for gear adjustment?
After mounting the setting should be such that you can wiggle the spur gear just a little bit (<0.5mm) by hand without moving the pinion. Too tight will give you too much friction, too loose will risk cogging over and wear out the gears. My way to get the right setting is to first, with the screws somewhat loose, set the pinion fully against the spur. Then ease it off a tiny bit and tighten the screws. Check the gap, adjust if necessary. Last edited by Olle P; 05-28-2015 at 07:21 AM. |
06-03-2015, 12:35 PM | #3 |
Rock Crawler Join Date: Aug 2011 Location: Kingsland, GA.
I usually use a small strip of notebook paper. Roll it between the spur and pinion, then tighten the motor screws. Remove paper and check the gap. Usually spot on and never had any issues that way.
06-03-2015, 12:40 PM | #4 |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: Tips for gear adjustment? |
06-04-2015, 08:21 AM | #5 |
Pebble Pounder Join Date: Jan 2013 Location: Bc
06-04-2015, 01:43 PM | #6 |
RCC Addict Join Date: Aug 2009 Location: Earth?
Paper trick works. I did that until I had done it so many times I was able to eyeball it.
06-04-2015, 02:01 PM | #7 | |
Moderator Join Date: Jan 2004 Location: chicago
| Re: Tips for gear adjustment? Quote:
paper trick works too but sometimes itll be a tad too snug or too loose. imho you can do a better job just by feel. | |
06-04-2015, 05:24 PM | #8 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Make sure to check the backlash at several locations on the spur gear. Not all spur gears are perfectly round.
06-04-2015, 05:55 PM | #9 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
I paper it, then run the motor and listen. Its pretty easy to hear when its to tight.
06-05-2015, 12:47 AM | #10 |
I actually started out using "the paper trick". Failed every time because the motor mount in my rig was (is) a little flexible and as I tighten the screws the pinion gets pressed closer to the motor. The paper just sucked up some of that flex, but the mounting was still way too tight.
Tips for gear adjustment? - Similar Threads | ||||
What does this adjustment do? | jhautz | Axial Yeti XL | 4 | 05-18-2015 07:17 AM |
RS4 RTR3 One Way and Gear Diff Adjustment Spring Set | BJoe | Non Crawler RC's | 2 | 01-21-2012 12:16 AM |
Setting pinion gear adjustment | Moab Bob | Axial SCX-10 | 6 | 11-05-2010 09:32 AM |
build tips and setup tips | iwantoffroad | Tamiya CR-01 | 7 | 12-04-2008 06:20 PM |
Motor mounting/gear mesh in R2D- Install Tips? | gr33nlite | Newbie General | 2 | 11-14-2007 11:53 PM |
