02-05-2005, 07:16 PM | #1 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
| I've seen lots of posts asking about Revo shafts...
...so I figured I'd take a few pics to hopefully clarify things. I figured I'd stick this in General since this doesn't apply to a specific vehicle. The part number for a complete Revo shaft is TRA5451. To find them online just go to Tower and type "5451" into the search box. They'll pop up. Here's the complete Revo assembly... ...to remove the stub axle all you have to do is push the cross pin out. There is no grub screw or anything that retains the cross pin...it's held in place by a bearing when installed in the Revo. After you've removed the cross pin the stub axle can be pulled out of the axle assembly. The Revo shafts are made to fit a 6mm diameter input/output shaft with flats on two sides. A yoke pin, Traxxas part number 5145, is included with each axle assembly, but a 2nd yoke pin will be required for the cross pin that was removed from the stub axle. So...to install Revos on a truck, you'll need the following...click'm for the page at Tower: TRA5451 (2 each) TRA5145 (1 package...6 per package) If you plan on installing the Revo shafts onto an E-Maxx transmission you'll need to remove material from the back of the yokes. If you don't the yokes won't slide fully onto the output shaft...the holes for the cross pin will be off about 1/16". Mods such as this may also be needed for other applications. The 5145 yoke pins are 15mm in length and will need to be trimmed to length. TRA4928 yokes include a 10mm long yoke pin, but I can't find the shorter yoke pins available seperately. Last edited by JasonInAugusta; 02-05-2005 at 07:19 PM. |
02-05-2005, 07:48 PM | #2 |
Rock Crawler Join Date: Dec 2004 Location: Land of the Free, because of the Brave
| Nice write-up. I was wondering about this very thing today while staring at 'em at the LHS. Would've bought 'em, but they only had one. |
02-06-2005, 11:39 AM | #3 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
well SOB I didn't buy the whole shaft cause i thought you would still have to change out the ends. i didn't know you could just pop that stub axle off |
02-06-2005, 02:08 PM | #4 |
Pebble Pounder Join Date: Feb 2005 Location: Scott Depot
to put them on a TXT you have to shorten the part that connects to the output shafts on both ends, then you can use the hardware that comes with the axles to secure them. i only bought pt no 5451 and used a dremel and the included hardware to mount them |
02-06-2005, 06:44 PM | #5 | |
Newbie Join Date: Jan 2005
02-06-2005, 06:53 PM | #6 |
Either will work. The problem is that the yoke bottoms out on the shaft before the holes for the cross pin align. |
02-06-2005, 08:38 PM | #7 |
Thanks.
02-06-2005, 09:54 PM | #8 | |
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
Next to the one that comes with the shafts... It's the perfect length to replace the cross-pin. Last edited by Jeckler; 10-11-2006 at 06:16 PM. | |
02-06-2005, 11:52 PM | #9 |
If those are the old E-Maxx ones, then you could use the ones from the Savage http://www2.towerhobbies.com/cgi-bin...?&I=LXDLG9&P=M |
02-24-2005, 06:47 PM | #10 | |
Rock Stacker Join Date: Feb 2005 Location: Rachel Rays Bed
03-30-2005, 03:04 PM | #11 |
Rock Crawler Join Date: Dec 2004 Location: www.ORCRC.com
I found this post from searching and thought it was a good place for my question..... How do you attach the revo shafts to a stampede tranny?? Please keep in mind that I haven't received my tranny yet and I have not bought the shafts yet. so if its complicated, pictures would be sweet! BTW I found this post but after I got done reading it, I'm still confused!!!!!! Revos on a pede tranny? Last edited by 4RnrRick; 03-30-2005 at 03:23 PM. |
03-30-2005, 06:08 PM | #12 |
the pede tranny is a 5mm output shaft and the revos are for a 6mm shaft. either use something else or just rely on the grub screw to hold it people say they work( which they do) but they have slop in them..i like my holes tighter |
03-31-2005, 06:46 AM | #13 |
Pebble Pounder Join Date: Mar 2005 Location: Ulysses (In my hick town)
How do you put one in an X factor with stock tranny and axel?
03-31-2005, 09:03 AM | #14 |
I had no idea the Revo's where so large! And for others that don't know, heres a picture of 'Pede sliders, Maxx 2.5 sliders and then the REVO that Toyofast took, (thanks for the picture Toyo!) http://www.rcrockgear.com/BC/PICT6094.jpg http://www.rcrockgear.com/BC/PICT6095.jpg |
03-31-2005, 09:40 AM | #15 |
Rock Crawler Join Date: May 2004 Location: DFW, Texas
For Revo shafts there are 3 different yokes I know of..... p/n 5453 http://www2.towerhobbies.com/cgi-bin...?&I=LXHFY5&P=7 p/n 5457 http://www2.towerhobbies.com/cgi-bin...?&I=LXHFZ2&P=V p/n 5458 http://www2.towerhobbies.com/cgi-bin...58&FVPROFIL=++ I did mine when the parts first came out so some of the revo parts weren't available. I had to piece everything together seperately. For an EMAXX tranny I used #5458. Grind the yoke down a smidge and enlarge the hole for the tranny's output. I ALSO used this same yoke on a bft pinion in x-factor axles. The stock xtm pinion will accept this yoke too. #5458 can also be used for maxx axles. Twin Force axles....probably, but I've never tried so I can't say for sure #5453 is used with TXT trannies I hear. You have to grind the end and TAP the hole for the setscrew to screw in. I'm guessing #5453 could be used with the PEDE tranny. It looks as if it has the smallest hole out of the 3 and would work best with the pede's 5mm shaft. MAYBE SOMEONE CAN CLARIFY THIS FOR US? .... We need to clear this subject up and make it into a sticky with all the different combinations of using the revo shafts. E-maxx/TXT/Pede trannies and all the different axles available....... I get asked alot about this subject also. |
09-08-2005, 10:12 AM | #16 |
Rock Crawler Join Date: Aug 2005 Location: Asia
any tips on what to do with a stock juggy2 tranny? i was at an lhs today and saw these ... unfortunately, just found this thread. maybe next week i'll get a set.
10-12-2005, 02:30 PM | #17 |
Newbie Join Date: Jul 2005 Location: Hanover
I heard you can put revo nuckles on a maxx? so you can do that easyer?
10-12-2005, 02:39 PM | #18 |
yes you can.. this thread was more about using them as driveshafts and not axles though
10-12-2005, 06:00 PM | #19 |
Rock Stacker Join Date: Jul 2005 Location: New Cumberland, Pa
Sorry to jump in and hijack this but anybody have any idea if or how it would be different to install these on a Juggy? Or yall think I'd be better off with Maxx shafts?
02-13-2006, 12:42 PM | #20 |
Newbie Join Date: Feb 2006 Location: LITCHFIELD PARK
good write up, I ordered my revo shafts and knuckles I got tired of replacing the stock Emaxx shafts I bought 4 of them and in 4 days I broke all 4 including an output yoke, all on a stock truck.
