05-20-2004, 11:43 AM | #1 |
Newbie Join Date: Apr 2004 Location: New Mexico
| Help assembling upgrade drive shafts on TXT-1 Help. I need to know what the correct method is for assembling the universals on the upgrade Traxxas Half shafts I have for my TXT-1. My first attempt split one side of the yoke where the pin goes through. I pushed it into one side and squeezed it with channel lock pliers to force it into the oppisite side with the above result. Couldn't do it with my fingers. Since I have a lot more of these to assemble I obviously need a different (better ) method of assembly. |
05-20-2004, 12:45 PM | #2 |
Quarry Creeper Join Date: Jan 2004 Location: Bend, OR
| Re: Help assembling upgrade drive shafts on TXT-1
Try soaking the yokes in hot tap water for a minute or two...it will soften them a little bit and make it much easier. You will probably even be able to do it by hand.
05-20-2004, 01:15 PM | #3 |
| Re: Help assembling upgrade drive shafts on TXT-1 Thanks a bunch. The hot water method worked easily with my fingers. RockyD |
