07-18-2016, 08:48 PM | #1 |
Rock Crawler Join Date: Nov 2006 Location: Spanish Springs, Nv
| MIP bypass valves
Has anybody tried these with powerstroke shocks? Was wondering how they would perform on a U4 rig.
07-18-2016, 09:30 PM | #2 |
Rock Crawler Join Date: Sep 2005 Location: Columbia, SC
| Re: MIP bypass valves
I have them in two sets of big bores on two U4 rigs, it's the only way I have found to get them tuned well for high speed. Sent from my iPad using Tapatalk |
07-19-2016, 10:54 AM | #3 |
Chassis & Tubework Vendor Join Date: May 2006 Location: Portland, OR
I have them in traxxas aluminum big bores also and yes they do make a noticeable difference.
07-19-2016, 09:38 PM | #4 |
Thanks for the info guys. |
07-21-2016, 08:00 AM | #5 |
Newbie Join Date: Nov 2014 Location: SW WA
One of my favorite upgrades to my c2. I might build another set for my c3. Sent from my XT1526 using Tapatalk |
07-21-2016, 08:01 AM | #6 |
Your best bet is to measure the pistons , shafts and bodies to make sure they fit. That's pretty much all that matters. If the dimensions are the same, the pistons won't know the difference . Sent from my XT1526 using Tapatalk |
07-21-2016, 12:26 PM | #7 |
Rock Crawler Join Date: Mar 2010 Location: Onalaska
I run on my SC trucks and if you take your time and effort and patients it well take you a good week over a period of time changing disc or oil or both but make one change at a time so you don't get miss up and right down what you did really help me and springs and real put your mind into it THEY ARE KILLER when I was running I had a set of shocks for the 2 tracks that I run with notes and don't give your info to others or they well be beating you lol your shock setup is top secret!! |
07-21-2016, 05:12 PM | #8 |
Sounds like I would need to get fired up for alot of tuning until I get it right.
07-22-2016, 07:18 AM | #9 |
| Re: MIP bypass valves Lets just say the more finer you take your time and get into them and numder one thing is don't get frustraed the finer they are,,don't get me wrong you will notice a big diffrence right of the bat but trust me they can and will get unbelievable better but one big big thing as said before change one thing at a time and take notes of every little thing you do is a must so you dont get lost but hope I'm not scareing you away from them because they are truly unreal I truely beleive this is only up grade you need to be competive out of box There that sweet if you put your mind in them for a bit even ,,I have got mine were over ruff stuff or around track in genral chassis don't move much now the suspension on other hand is working like crazy thats another thing to I video my boys as they run on track so i could see what was working to hope this helps,,, getting cramp in fingers from typing lol. |
07-22-2016, 07:53 AM | #10 |
I love my bypass pistons. You should be able to tune the compression and extension separate from each other. Anything else is unacceptable. I think my favorite thing about them is that most will never want to deal with the tuning to get it right. That means its a big advantage for me because I am willing to put in the time and at that point, it makes a huge difference. I did a bit of a write up in my build thread. Dlux Berg Build |
07-22-2016, 08:46 AM | #11 | |
| Re: MIP bypass valves Quote:
07-22-2016, 08:48 AM | #12 |
Its cool. Thanks for the insight. I run clapped out mini T pink springs. I dont know of any springs that are significantly softer. I have softened up the pink springs by hand grinding them a bit. It brought other negative characteristics though. |
07-22-2016, 03:53 PM | #13 |
Newbie Join Date: Jul 2016 Location: Indonesia
it's a big difference using bypass pistons, planning to make another set. |
07-23-2016, 09:34 AM | #14 |
Don't know if any of you fellers know about the RPM shock valves ?? there not as high tech but still a advantage semi different set up,, you tune with hole sizes but still have a split bypass valve setup for choosing your rebound style in them. But I run them for a year or so before the MIP real shock valves came out and same thing if you dedicate yourself to them for a bit and do the work take the notes they work pretty darn good to I did have a little problem of and on with valve sticking and matching piston to bore size,, thought I would throw these in the mix to but to be truthful I don't know if they even make any more..
07-23-2016, 12:23 PM | #15 |
Moderator Join Date: Jan 2004 Location: chicago
i have the rpm clicker pistons in a couple rc10's, they work killer once you figure out the right combo to use.
07-23-2016, 02:43 PM | #16 |
| Re: MIP bypass valves LOL never heard them called that but perfect they should rename them that ya I run them for I can't really remember but for will like say only problem I had with them is the clicker would stop clicking lol manly my fault from missing with to much was always trying to make better and they were bad ass and funny no one wanted to deal with and really just putting them in they were improvment as long as you didn't get to thick oil in them.
MIP bypass valves - Similar Threads | ||||
HH Rx bypass adapter | 808TF2 | Electronics | 1 | 10-31-2015 04:47 AM |
RC Bypass shocks | motas | General Scale Talk | 6 | 05-25-2015 11:37 AM |
Help with BEC install us Rx Bypass | NorOr Markie | Electronics | 11 | 01-16-2015 10:16 PM |
Receiver bypass adapter | Chris_The_Battery_Man | Electronics | 6 | 08-29-2011 04:24 PM |
can I bypass a BEC or is that FUBAR,,, | grouser | Electronics | 16 | 06-14-2009 06:02 PM |
