01-18-2017, 01:16 PM | #1 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| ring and gear shims
Where does one find shims so I can shim my pinion gear and ring gear to remove play and get good gear mesh?
01-18-2017, 01:41 PM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: ring and gear shims |
01-18-2017, 02:37 PM | #3 |
Yokohomo # ZC-S50S is nice since it comes with some .05mm shims so you can really dial it in. For stock plastic ar60 housings Hpi # 103368 works mint as a solid pinion spacer. |
01-18-2017, 04:02 PM | #4 |
Thanks guys, I picked up some redcat everest 10 axles and right now just building the rear. My parts list is all axial parts HD UD gears Hot racing spool Strc lockouts and SS axles (red cat uses same front axle as rear just with a steering link with turnbuckles to the housing to lockout the knuckles) The ring gear fits great, the pinion is going to need a spacer. |
01-20-2017, 05:40 PM | #5 |
All good suggestions above, I have an assortment of Yokomo steel and teflon, Kyosho steel, HPI steel, and CRC (Calandra Racing Concepts) shims that work great. Gotta say CRC (Calandra Racing Concepts has the best selection of diameters and thickness I've seen anywhere, probably better than Yokomo which is a close second. CRC, Yokomo and Kyosho are very high quality. |
01-20-2017, 09:49 PM | #6 |
Sounds like I need to invest in a digital caliper
01-20-2017, 10:15 PM | #7 |
I found it hard to measure for the pinion shims. Much easier to just eyeball it and get the pin in. CRC set looks good too, 20 pack is nice. |
01-21-2017, 07:39 AM | #8 | |
| Re: ring and gear shims Quote:
Thanks | |
01-21-2017, 10:35 PM | #9 |
Lol, you're welcome and good to hear! |
02-17-2017, 12:05 AM | #10 |
| Re: ring and gear shims https://www.rcplanet.com/calndra-rac...c54aAoQi8P8HAQ https://www.google.com/search?q=Yoko...Sy1AYMQgTYIoAI Are these the right shims? Last edited by hillbillyrc; 02-17-2017 at 12:14 AM. Reason: added more info + another link |
02-17-2017, 07:57 PM | #11 |
Yes. 5mm inside diameter, a variety of thicknesses.
02-17-2017, 10:29 PM | #12 |
I just ordered up some crc shims and some grease
03-05-2017, 06:35 PM | #13 | |
Newbie Join Date: Jul 2016 Location: Los Lunas!
03-05-2017, 09:22 PM | #14 |
Pebble Pounder Join Date: Jan 2017 Location: Kalispell
Thanks for the link, hillbillyrc!
03-05-2017, 09:49 PM | #15 |
Spool https://www.google.com/search?q=scx1...RqgCjEQgTYIxwE Underdrive gears https://www.amazon.com/Axial-Racing-.../dp/B001QLFP16 Lockouts and axle shafts Axial SCX10 Bearings Welcome to Locked Up RC - Scale Performance Parts Not all places are the cheapest price just reference on parts. I have only built my rear axle so far as I need to save for more parts for the front axle, but plan to ran Tss brass knuckles C-hubs not sure yet Cvd axles Locked up rc heavyweight FI locker Axial overdrive gears And locked up rc bearings. Here is my finished rear axle besides parts it's been shaved too Before shaving of housing |
03-12-2017, 09:12 AM | #16 |
man thanks a million i just finished redoing the 6 wheeler then lost the tranny any insight on what could hold up to the 6's demands would the all metal trans from china hold up or should i go with the redcat everest for parts for OD gears what do you think of the helical stuff from boom racing or is the axial stuff a gold standard as far as the durability and strength goes??? Last edited by mta; 03-12-2017 at 09:15 AM. |
03-12-2017, 10:13 AM | #17 |
Axial for the grars, don't know anything about boom racing gears. As for the trans I would say again axial, just cause you can get metal gears, better outputs and more. They might cost more but worth it when you don't have to replace it down the road.
03-13-2017, 01:44 PM | #18 |
03-14-2017, 01:53 PM | #19 |
Traxxas - part #1985
03-14-2017, 02:59 PM | #20 |
The Traxxas shims are useful, but they are plastic not steel and only come in one or two rather thick versions. I keep both in my box, but the fine steel shims in varying thickness are better for most gear shimming. |
ring and gear shims - Similar Threads | ||||
How to place shims to move pinion away from ring gear | relay1 | Axial Yeti XL | 8 | 07-03-2015 05:44 PM |
Ring Gear Shims | JeremyH | Losi Mini-Rock Crawler | 19 | 10-16-2013 11:10 AM |
worm gear shims | squish72 | Team Losi Comp Crawler | 3 | 04-26-2010 02:45 PM |
gear shims on lnc | losiredcatcrawler | Team Losi Comp Crawler | 3 | 03-24-2010 02:56 PM |
worm gear shims remove or not | love2crwl | Newbie General | 11 | 01-12-2010 11:33 PM |
