08-09-2017, 08:29 AM | #1 |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Gearing/motor turn changes
I'm going to toss this here since it crosses over between mechanical and electrical. I have a fairly heavy rig at 11lbs, which I just made a tire change to. Prior to and currently I have no heat issues with either the 35 t motor nor the ESC running 3S. My gearing is 64/20 spur/pinion, 1.78:1 transmission, 1.47:1 transfer case and 43/13 front gears. So if I am doing this right my final gear ratio is around 27.689:1. I was running og rock beast, and when mounted to the rig was a touch faster then I really needed, but all in all worked as trail rig, G6 crawler. So with tires I was at about 4.082:1. I switched up to the RBXL's which place me at 4.32. Not a huge change but just enough for me to want to make a few changes to get a little better gear ration. I am going to pick up a 11t and 14t pinion to land at 50:1or 39:1. Might pick up a few more to get it where it feels right. That was a long way to get to the question. Is it better to get to my desired wheel speed using gearing or motor turns? I am considering moving to a 45t motor and dropping the pinion to see where the speed ends up. I guess another way to ask it is do I want to fit the motor to the gearing or gearing to the motor. Last edited by Ditchrat; 08-09-2017 at 08:32 AM. |
08-09-2017, 11:27 AM | #2 |
| Re: Gearing/motor turn changes
Do the pinion gear. Work the motor until it gets hot.
Gearing/motor turn changes - Similar Threads | ||||
High Turn Motor & Long Gearing vs Low Turn Motor & Short Gearing. | Hardcoretam | Electronics | 11 | 03-15-2017 11:23 PM |
Higher Turn Motor Vs Lower Turn Motor ? | ReignMan | Newbie General | 10 | 11-15-2009 10:40 PM |
higher turn motor or lower turn motor......... | bob1961 | Newbie General | 6 | 03-18-2008 09:16 PM |
