10-18-2017, 06:49 AM | #1 |
Rock Crawler Join Date: Dec 2014 Location: Union Bridge, MD
| Scale transmission shear point
I was wondering what the weak link is or should be when running a scale transmission or a trans without a slipper. Does anyone have a shear pin of sorts to protect the driveline? I am prepping for a winter project and as I do this question keeps coming back to me.
10-18-2017, 09:31 AM | #2 |
Rock Stacker Join Date: Jun 2016 Location: Squaw Valley
| Re: Scale transmission shear point
If your worried about that then why not run a slipper. You can always tighten it to the point where it wont slip. I have ran both ways, but i think i like having the clutch. If anything it acts as a buffer so nothing does sheer. Your sheer point will be the pin holding your spur/clutch in. The pins holding the drivelines in are heavier duty then the spur pin. Naturally thats your weak point. If you try to get rid of all slack and run direct eventually and always you will break somewhere. Better a pin sheer then jammin up your gears and something wrong happening in the tranny casing. Dont worry so much about your driveshafts. Worry about the internals of your diffs and center tranny. I have done that to. Replace gears since I didnt have a that buffer zone to take the impact. I have 9 crawlers. Losi, Redcat, Vaterra, Gmade, and Axial crawlers. I prefer a clutch. Especially since most of all gears are 48 pitch. If it was all 32 pitch then not as much too worry. 48 pitch is farely fine. So there yah go. Lol. Hope that answered any or atleast some questions. Oh. If your running brushless. I would always run a slipper. I do run crawlers everyday of my life. Even at work on breaks. I work in Kings Canyon National Park which is 6300 ft. Elevation.The rock crawling there is hellascious. Running my way I think youll find out your whole powertrain will last longer including your motor. But hey. This is my opinion. Everyone has one. Right!! LOL. Sent from my SAMSUNG-SM-N900A using Tapatalk Last edited by Ctrain57; 10-18-2017 at 09:35 AM. |
10-18-2017, 09:59 AM | #3 |
No real sacrificial part on scale transmission setups I have (GCM and RC4WD). The gears are all steel, the driveshafts are steel, and the drive pins are all 2 mm or larger so those are pretty stout as well. You could run plastic drive shafts as a cheap, replaceable part or just exercise some throttle discipline when bound up and not worry about it. |
10-18-2017, 10:34 AM | #4 | |
| Re: Scale transmission shear point Quote:
10-18-2017, 11:23 AM | #5 |
Slipper clutches are an annoyance in anything that is not racing. I tighten them all down as hard as I can. The shear point is your trigger finger. |
10-23-2017, 09:23 AM | #6 |
Cool thanks everyone. I'm getting ready to start a thread in 1.9 scalers. You will see why I asked the question. Sent from my XT1585 using Tapatalk |
02-25-2018, 09:08 AM | #7 | |
Sent from my SAMSUNG-SM-N900A using Tapatalk | |
02-25-2018, 10:52 AM | #8 |
Pebble Pounder Join Date: May 2016 Location: France
The weak point on my driveline are Axial stock shaft the plastic part twist but doesn't break, I just need to replace them once in a while, and it doesn't left me stranded with a broken truck |
02-25-2018, 01:43 PM | #9 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
The slipper clutch in my Spawn kit is great. Very consistent and really takes a serious bind to make it slip. But whatevs. |
Scale transmission shear point - Similar Threads | ||||
Double Shear Panhard Mount for Toyzuki 10.2 Chassis | Duuuuuuuude | Chassis and Suspension | 11 | 02-27-2017 03:07 PM |
New Mini 8" Brake/Shear | Chumley54 | Tools, and Procedures | 14 | 05-26-2016 04:59 PM |
Metal shear actuator | JohnRobHolmes | Tools, and Procedures | 17 | 06-30-2011 01:33 PM |
Non Newtonian Shear Thickening Fluid | Talico | General Crawlers | 9 | 04-13-2011 07:56 AM |
