Thread: Desert Lizard Two Stage Internal Spring Shock
Old 11-21-2017, 02:01 PM   #1
Default Desert Lizard Two Stage Internal Spring Shock
Hello,
Does anyone have any experience or knowledge with these Desert Lizard shocks? I have been trying to look into them but am having a hard time finding info or people who have used them. I like the look and like the concept behind the dual internal spring.
https://www.hobbytown.com/120mm-dese...-120bk/p632379
Thanks
travelin_Trees is offline   Reply With Quote
Old 11-21-2017, 02:21 PM   #2
Default Re: Desert Lizard Two Stage Internal Spring Shock
I've got a set on my R1/RS10. They're not the smoothest thing out there by any means, but they package nicely (the small-ish overall diameter allowed them to be mounted in a tight place.) Running in the semi-droop setup (short spring under piston, medium on top) they've got enough internal friction that I didn't even bother filling them with oil, just a couple drops to keep things sliding. They fit my needs for that car better than anything else I could find, I'd probably buy them again. That being said, I wouldn't even consider them for something that can go over 10mph.
TheLetterJ is offline   Reply With Quote
Old 11-21-2017, 04:22 PM   #3
ok cool, i think i might try a set out. I have a frankenstein of an AX10 im trying to build right now and wanted to get a different look for the shocks. Ill post some pics when im done. Still new to the whole rc crawler world. Thanks for the feedback.
Desert Lizard Two Stage Internal Spring Shock - Similar Threads
RC4WD Internal Spring Shock Advice... T Bone 347 Axial SCX-10 3 06-09-2012 05:54 PM
Black internal spring air shock 100mm are they any good? MIcrawler General Crawlers 6 12-10-2011 10:56 PM
Oil in Internal Spring Shock? Tedro Newbie General 4 08-14-2010 01:09 PM
Internal spring/ and stock spring set up wassaakk Newbie General 7 06-06-2010 06:53 PM
