01-22-2018, 10:52 PM | #1 |
Newbie Join Date: Jan 2018 Location: Newberg
| differential gearing help!
I just got a new scx10 ii. I am putting new axles in. Should I change up the stock gearing in the diff? or leave it?
01-22-2018, 11:03 PM | #2 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: differential gearing help!
What axles you putting in it? If same as stock I believe there is only overdrive gears and stock gears.
01-23-2018, 05:00 PM | #3 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: differential gearing help! |
01-15-2019, 08:15 PM | #4 |
Quarry Creeper Join Date: Jan 2016 Location: Southampton
Depends on what you are going to do with the rig. At the very least make sure the gear mesh is good and shim as needed. I prefer the aftermarket gears, they are manufactured better. Most aftermarket gears are machined from better material. A lot of the stock gears are not. They are sintered (pressed metal particles) I believe. |
differential gearing help! - Similar Threads | ||||
Dig, differential axle gearing or ... ? | anuthabubba | Vaterra Ascender | 6 | 09-12-2016 05:55 PM |
Differential | basher1 | Axial Yeti XL | 52 | 07-06-2016 02:47 PM |
differential | mitchr97 | Axial SCX-10 | 11 | 03-04-2013 02:29 PM |
differential | mitchr97 | Axial SCX-10 | 1 | 10-31-2012 01:37 AM |
Is this the differential for the WK?? | GUERO4X4 | HPI Wheely King | 7 | 06-29-2007 04:46 AM |
