01-31-2018, 06:06 PM | #1 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| RC4WD 6 Lug Steel Wheel Hex Hub w/Brake Rotor
Saw these on amainhobbies today https://www.amainhobbies.com/rc4wd-6...zs0530/p656373 Can someone help me here please. My question is: Art these RC4WD 6 lug steel wheel hex hubs designed for SLW hub bolt pattern??? SLW hubs compatible? Thank you Last edited by Teng; 01-31-2018 at 06:09 PM. |
01-31-2018, 06:16 PM | #2 |
| Re: RC4WD 6 Lug Steel Wheel Hex Hub w/Brake Rotor
Nope for rc4wd steelies.
01-31-2018, 06:31 PM | #3 |
SSD has 3 different sizes of brake rotor hubs that ARE SLW compatible. I just got a set of their narrowest ones last week, just a tiny bit narrower than VP .225"s, then they have +3mm (roughly .350") and +6mm (roughly .475") At $12 a pair, they're about the same, if not cheaper than those RC4WD ones.
01-31-2018, 07:55 PM | #4 | |
| Re: RC4WD 6 Lug Steel Wheel Hex Hub w/Brake Rotor Quote:
Anyway, I just wish SSD comes out scale screws for their SSD RC Wheel Hub w/Brake Rotor next time ( https://www.amainhobbies.com/ssd-rc-...d00192/p674920 ) Thank you | |
02-01-2018, 02:58 AM | #5 |
RCC Addict Join Date: Oct 2014 Location: UK
I actually designed those for RC4WD a long time ago. The RC4WD bolt patter is not SLW compatible. Neither is the diameter of the step on the front of hub. RC4WD hubs and SLW compatible hubs are just two different things. You maybe wandering why SSD dont use scale hardware on wheel hubs (given that I started the scale bolts thing at RC4WD). I dont believe in using scale bolts anywhere that you may need to crank down hard (steel wheel assembly). You could just get M2.5 x 8mm scale bolts from Locked Up or RC4WD if you want to try it. |
02-01-2018, 04:23 AM | #6 |
Okay I will going to order yours https://www.amainhobbies.com/ssd-rc-...d00192/p674920 Unfortunately they are in back order now. Just waiting they back in stock and check out only. Thank you SSD |
