02-19-2005, 08:43 PM | #1 |
Newbie Join Date: Dec 2004
| project rubicon!!!
cehck out my new truck. i made the chassis last night. look at the pics and let me know what you think>>>>> http://groups.msn.com/myrccrawler/shoebox.msnw?Page=2 |
02-19-2005, 09:34 PM | #2 |
Pebble Pounder Join Date: Dec 2004 Location: Delaware A Place With No Rocks!
its nice but i would make it a little lower. it would make it look even more scale
02-19-2005, 10:21 PM | #3 |
| project rubicon!!!!
i did have it lowered at first, but i would hit the finder before i hit my max articulation. so i rised it enough to where i can get max atriculation right before i hit the finder. i think it turned out ok. it was probably one of the hardest trucks i have done. only because i had to make a chassis to fit a body. other than that it was a fun project. by the way if you ever get a 1/6 newbright truck.....hold onto the undercarage of the body. if you have a snow plow and the right tires to put on there. it will plow snow pretty good. i put a set of stock tmaxx tires with tire chains on there and it plowed pretty good.
02-20-2005, 07:30 AM | #4 |
Quarry Creeper Join Date: May 2004
extend your wheel base in the back so the wheel fits under the wheel well, also lower the bady, trim the fenders, then create some fender flares to give it a cool look
02-21-2005, 04:00 PM | #5 |
| project rubicon
the only reason that my axles set a little to the inside is so when my shocks fully compress he tires go directly to the center of the wheel well so i dont rub on anyting. i have 4'' shocks and i put 3'' springs on it. it still has the same articulation but it just sits lower. ill get a pic of it and put it on the link above.
02-21-2005, 04:14 PM | #6 |
cool then, nice work
03-01-2005, 07:55 PM | #7 |
Rock Stacker Join Date: Feb 2005 Location: Redding CA
looks good i like it
03-02-2005, 12:07 AM | #8 |
Newbie Join Date: Jan 2005
I LIKE IT ! Gotta see some outdoors pics! Kevin |
03-03-2005, 02:19 PM | #9 |
Quarry Creeper Join Date: May 2004 Location: Neosho
Cut the fenders and lower it back down. Would look and perform 200% better.
