Thread: Discussing Vanquish AR60 axle sets
Old 06-14-2019, 08:50 AM   #1
Default Discussing Vanquish AR60 axle sets
After destroying on my V1-HD bearings and shaft with my 8.8lb RR10 I look at the different solutions VP offers, comparing them strengthwise, regarding to the bearings and shaft diameter. V1-HD go for 65$
RCV #VPS07392 for 80 dollars:
Highlights: Bigger inner berarings with 8x15x5mm measures instead of stocks 10x15x4mm.
Outer bearings 6x11x4 instead of stocks 5x11x4 mm. This reduction of bearing diameter is caused by the stronger axles they are offering: 6mm stub axle instead of 5mm threaded stub.
On the stronger axles M6 nuts might hold better then M5 usually used. But will these outer bearings last longer? I assume there is going to be be a lot of load to carry.
VXD #VPS08110 for 125 dollars:
Highlights: Ultrahigh strength 4-way cross pin and 60 degrees of steering angle! This compared to 45 degrees on the VVD's!!
Stiffness with squared locker engagemend design on the special spool, with increased cross sectional area.
VP’s customer service is talking about to bring them back on market soon.
60 degrees for the VXD's is quiet a word, since I can't use the complete V1-HD angle without rattling. What about your experience with these special priced solutions?
Gesendet von meinem SM-G955F mit Tapatalk
ToCrawl is offline   Reply With Quote
Old 06-16-2019, 10:39 AM   #2
Default Re: Discussing Vanquish AR60 axle sets
Sounds to me like you need a set of Eriks 8mm FBA axles.
https://dluxfab.ecwid.com/#!/FBA-Axl...tegory=6232189
FBA axle shafts
mikemcE is offline   Reply With Quote
Discussing Vanquish AR60 axle sets - Similar Threads
vanquish wraith link on ar60 axle with vanquish xr10 knuckles? T3rry Axial AX10 2nd-gen 2 04-28-2013 06:11 PM
