07-01-2019, 08:16 AM | #1 |
Pebble Pounder Join Date: Mar 2012 Location: Greece
| 2.2 comp chassis and links for a rig based on AR60 Bomber axles
I have a bomber and I was thinking to take the axles and a 2.2 chassis,links to convert it to a crawler. Are there any available comp chassis and links to fit without modifications to these axles? |
07-01-2019, 09:45 AM | #2 |
Quarry Creeper Join Date: May 2017 Location: Devon
| Re: 2.2 comp chassis and links for a rig based on AR60 Bomber axles
I see loads of comp rigs with ar60 axles... Not sure what else to state on that other than check out the other 2.2 forums here - sportsman / shafty stuff that is, not moa of course! Sent from my Pixel 3 using Tapatalk |
07-01-2019, 10:05 AM | #3 |
5th dimension suckerpunch and Krazedbuilds unstuck both work great with any axle.
07-01-2019, 12:22 PM | #4 |
Dravtech if he's still trading: http://www.dravtech.net/?product_cat=chassis Guessing these are fine with ar60... Sent from my Pixel 3 using Tapatalk |
07-01-2019, 03:33 PM | #5 |
Thanks.I will contact for more info.I like suckerpunch chassis.
07-01-2019, 03:54 PM | #6 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
unstuck v2 by crazed builds. Erik D lux sells and makes the links. you will need to source upper links. also.. you will need a different trans other than what is in your bomber. hamburger is nice. cheeseburger too. |
07-01-2019, 04:12 PM | #7 |
Pebble Pounder Join Date: Mar 2005 Location: England
Got a sucker punch chassis myself in yellow being built with ar60 front and ar44 rear Great chassis and great guy to deal with Sent from my Moto G (4) using Tapatalk |
07-01-2019, 05:38 PM | #8 |
Nice!What are you going to use for links and lower link mounts?
07-07-2019, 05:01 AM | #9 |
I need a little help about the build. My transmission comes like that. What parts do I need to get it ready? Do I have to use slipper clutch or something like Slipper Eliminator IRC00082? https://prnt.sc/obnru1 |
07-07-2019, 06:47 AM | #10 |
Quarry Creeper Join Date: Jan 2016 Location: Southampton
Get a slipper eliminator for sure. Dont need/want on a shafty. Get steel gears for the tranny. I put Integy in mine and love them. I also drilled the outputshafts so I could use "pin" style setscrews to hold driveshafts. Cool build, looking forward to watching it come to fruition. |
07-07-2019, 07:22 AM | #11 | |
| Re: 2.2 comp chassis and links for a rig based on AR60 Bomber axles Quote:
How many teeth spur-pinion is suggested to start for using 32p gears and 3s battery? Στλθηκε απ το PRO 6 Plus μου χρησιμοποιντας Tapatalk | |
07-07-2019, 09:47 AM | #12 |
This is how far I have got in building mine. Just waiting on parts and making the top links now Sent from my Moto G (4) using Tapatalk |
07-07-2019, 10:18 AM | #13 |
Looking good. Στλθηκε απ το PRO 6 Plus μου χρησιμοποιντας Tapatalk |
07-08-2019, 07:32 AM | #14 |
Should wraith 32p spur fit on vanquish slipper eliminator?It has only 3 holes. |
07-08-2019, 07:57 AM | #15 |
Yes just line up three holes and use those. It will be fine Sent from my Moto G (4) using Tapatalk |
07-08-2019, 08:36 AM | #16 |
With hindsight it might not work you may need a spur gear like this one from associated but it's 48p not 32p As you can see it has more holes in it Someone else will probably know better Sent from my Moto G (4) using Tapatalk |
07-08-2019, 10:01 AM | #17 |
3 holes are fine.
07-08-2019, 10:53 AM | #18 |
Damn right first time Sent from my Moto G (4) using Tapatalk |
07-08-2019, 05:41 PM | #19 |
Thanks both of you.
08-24-2019, 11:31 AM | #20 |
I want to narrow my voodoo tires.I have Crawler Innovations 6 bolt 1'' wheels.Do I have to narrow them too?
