02-27-2020, 03:00 PM | #1 |
Rock Stacker Join Date: Jan 2019 Location: 'Burque
| RC4WD King Piggyback Shocks Question
Hi there, Anyone know if the faux reservoir in these bad boys can be removed? Thinking about getting a set to replace the faux plastic reservoir on my Bomber |
02-27-2020, 03:59 PM | #2 |
| Re: RC4WD King Piggyback Shocks Question
Don't waste your money on those. There are plenty of cheap ones on eBay if you just want the tops. I'm not sure they'll fit, but here's an option. https://www.ebay.com/itm/4pcs-110mm-...8AAOSw-itXuRX3 Or this: https://www.ebay.com/itm/Axial-Icon-...IAAOSwKLxbaJhF |
02-27-2020, 05:26 PM | #3 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
Like Jato said, dont waste your money on them. They can hold oil but usually leak. But worse, is the shafts and body are not coated with anything and just score terribly. The caps are a single machined piece so you would need to cut it off and sand it smooth. EDIT: NVM i see you are just wanting the caps. Are the bomber shocks stock? These are much smaller caps than the bomber, like SCX sized but they also thread on the inside of shock body. Last edited by Joshs4x4toyz; 02-27-2020 at 05:42 PM. |
RC4WD King Piggyback Shocks Question - Similar Threads | ||||
G-Made Piggyback shocks vs. RC4WD King shocks | crwlnCreeper | Axial Wraith | 33 | 01-20-2016 09:48 AM |
