Cross RC SG4 vs RC4WD C2X I have a TRX Bronco which I thoroughly enjoy. Thinking about getting a second truck, which should preferably be a hard body. The two choices I have are the Cross RC SG4 and the RC4WD C2X. Just wanted to get a feel from those who have some experience with these rigs what their opinions are. This would help in my decision. Alternatively, is to just get another TRX kit and fit a LC70 body. |
Re: Cross RC SG4 vs RC4WD C2X Neither are going to be as good performers as the TRX but the RC4WD I would stay away from, their quality is shitty at best. I’ve just sold my TF2 and won’t buy another product from them unless there’s a huge change in quality. |
Re: Cross RC SG4 vs RC4WD C2X Both CrossRC and RC4WD makes low quality rigs. I highly suggest getting another TRX-4 and putting a hard body on it. |
Re: Cross RC SG4 vs RC4WD C2X I would go for the rc4wd out of the two. I have a trailfinder and love it. It's been a great rig. The way I have mine set up is not for comps but for fun. I have lots into mine and it's been a very dependable rig for the trails. The quality of rc4wd is pretty good imo but its definitely not like the trx4. Go for the c2x, always fun to have a a variety of trucks. |
Re: Cross RC SG4 vs RC4WD C2X Quote:
X2, bunch of great build threads in TF2 section, here's a few. Edit: My TF2 is quite capable after some basic free/cheap mods and Pitbull Braven Ironsides tires, it's a joy to drive but requires more thought when driving! "thumbsup" http://www.rccrawler.com/forum/rc4wd...tf2-build.html http://www.rccrawler.com/forum/rc4wd...tion-yota.html http://www.rccrawler.com/forum/rc4wd...nized-tf2.html http://www.rccrawler.com/forum/rc4wd...ew2-rocks.html http://www.rccrawler.com/forum/rc4wd...f2-thread.html http://www.rccrawler.com/forum/rc4wd...n-fishing.html http://www.rccrawler.com/forum/rc4wd...iny-truck.html |
Re: Cross RC SG4 vs RC4WD C2X Thanks everyone, appreciate the comments. I must admit I do like the off-roading capability of the TRX 4 compared to some other brands. Also like the 2-speed/lockers. However, it would be nice to have a hardbody rig as well, but since I don't plan on competing, a scale chassis is probably not totally needed. I would like a pickup style body though and have only seen the LC70 being fitted to a TRX 4. Doesn't seem to be much out there to fit. A Cross SG4 Demon style would be neat though, but I'm not sure if it will fit on a TRX chassis. Any suggestions on other bodies will be welcomed. |
Re: Cross RC SG4 vs RC4WD C2X I built a TRX-4 kit and a TF2 LWB kit. First Cross kit is in the mail so I can't speak to that yet. I will say my personal experience with RC4WD axles for one build, the TF2 kit and a few other parts were overpriced and very poor quality in terms of fit, machining and functionality. As already said, if you're looking to compare kit quality or performance of the TRX to a scale oriented platform you're going to be disappointed. |
I have had three TF2s, and they have all been aggravating disappointments. The first time was shortly after the truck came out, so I understand some of the issues. But, wanting a REALLY good looking scale (C1) rig, I bought another, had all of the same issues, a couple of years went by, hoping they'd fix the issues, or any issue, and it turned out to be the same piece of junk. The CX2 is basically a TF2 on steroids, and shares many of its components, both good and bad. The good: • Chassis. It is very nice, well made. • Core drive train (transmission and transfer case). Both of these are well made, and look very scale. • The body. It is hard to find a truck that looks this good when it is put together. But, it also is on the "Bad" list The bad: • Outer drive train. From the wheels to the transfer case is junk. The gears strip, the hexes strip, when wheels do not go together properly. On all rigs the drive shafts broke on the very first pack. • Suspension. Junk. None of the kits I had could be assembled per the instructions. The holes were not in the right locations, the hardware stripped, and parts just did not line up without modification. The rod-ends are junk, both plastic and metal. • The body. First, getting it on and off is VERY annoying, having to bolt it on and off. Two out of the three bodies were not right, one was warped and the other just did not fit properly. • Bumps. They are the same bumpers on the TF2 and CX2, and will break the first run. If these rigs ran around the $200-250 mark, their issues would be expected, and tolerated. But at $400+ ($500 for the CX2), the long standing issues they have are just unacceptable. Recommend looking at the Element kit, it is a very good rig for the price, has different options for over/under drive, has an insane amount of steering, and can be made into whatever style of rig you want. |
Yes, that's one must upgrade immediately part. :ror:"thumbsup" For RC4WD I consider it necessary to enjoy tinkering and making things work. https://www.crossrc.us/product-categ...litary-trucks/ Cross RC GC-4, GC-4M, HC-4 or HC-6 imo HumboldtEF built the BC-8. |
Re: Cross RC SG4 vs RC4WD C2X Yep stock driveshafts are junk, I've never really had any other issues with these TF2 trucks although I tend to tinker and go over things with a fine tooth comb, I've had four of five of these and still have two Marlins. I do agree that the asking price is a little steep when you have to disassemble and check everything before running it. The hardware sucks, you can usually get by with it if you have good quality tools but even then I'll usually replace all of it over time. One of my first TF2s was the kit version and I did comp with it in class 2 and took 2nd place a few times with it, I don't comp anymore but they can be made capable. Don't be scared of a TF2 just know you'll have to go over it well and correct some things but once you do that they are pretty solid. |
Re: Cross RC SG4 vs RC4WD C2X Much appreciated everyone. |
Re: Cross RC SG4 vs RC4WD C2X I have the c2x and the cross spc4 which is similar to sg4. Like everyone said any rc4wd needs work out of the box. Changed axles to ssd pro44 , driveshafts ,longer shock hoops and and shocks. Having done all this i do like my c2x and it performs pretty good. The spc4 is a nice build but purely a trail rig. the suspension setup is rather unique and so is the drivetrain. So far it hasn't failed but the gears look like they come out of a watch. |
Re: Cross RC SG4 vs RC4WD C2X How does the Boom Racing BRX-01 compare to TF2 and Cross RC? Is the quality any better? I'm also like OP looking for a scale hard body rig and the BRX-01 with the LC70 is an option. |
Re: Cross RC SG4 vs RC4WD C2X The LC70 is a cool-looking truck. The BRX-01 is on my list of potential chassis when I start my next project on a 313mm wheelbase. My last one was on a 275mm base and I used a Gellande II kit and it turned out to be one of the most solid chassis I've ever built in 30+ years of RC. Almost no play anywhere. Just amazing. But yeah. Thinking of a BRX-01 myself with either a 4-door XJ body, an RC4WD Blazer so I can build a CUCV, or a Comanche. |
