02-22-2007, 10:58 PM | #1 |
RCC Addict Join Date: May 2005 Location: I live Here
| Stampede TRanny ?s
what is the difference between a spur adpater and a slipper clutch ? ? ? what is recomended for...... 1.- Basher 2.- Comp Rig Thanks for the input ahead of time |
02-22-2007, 11:35 PM | #2 | |
Quarry Creeper Join Date: Jul 2004 Location: 808
The adapter is like a locker. No slipping. A slipper....slips. For a basher, Id say slipper. Comp, adapter. | |
02-22-2007, 11:56 PM | #3 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
If you have brushless I would suggest the slipper as so the trans can slip not strip. If you plan to run a lathe motor just go with the lock out.
03-20-2007, 12:54 PM | #4 |
i just put the tranny together but the spur adapter i think has parts missing i don't think tammies hobbies would send incomplete so i must be looking over something i can't find the adapter goes on the shaft then the spur gear but how do you lock the spur gear in place |
03-20-2007, 01:02 PM | #5 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
i used three screws like so: |
03-20-2007, 01:07 PM | #6 |
that is what i thought i have seen some sort of black plastic adapter that goes on top maybe i'm mistaking it for another tranny Thanks obi will follow the advice and finish up |
03-21-2007, 02:27 PM | #7 |
Rock Crawler Join Date: Jan 2007 Location: Long Island NY
Obi has the spur adaptor on his trans http://www.rcboyz.org/tra3693.jpg 3 2mm screws hold the spur gear in place |
03-21-2007, 03:37 PM | #8 | |
Quarry Creeper Join Date: Nov 2005 Location: The Great White North
Basically the spur gear is sandwiched between 2 metal plates, and the rulon pegs pressed into the spur gear are used for friction. By tightening the nut down, you increase the clamping force on the spur gear, and it will slip less. | |
04-22-2007, 08:46 PM | #9 |
Newbie Join Date: Mar 2007 Location: Augusta
I bought a stampede tranny on ebay. It was pulled off a brand new stampede. Would this have the slipper already installed?
04-22-2007, 09:03 PM | #10 |
I know of the black spur adaptor your referring to, and believe it or not, I don't think they come with those 3 screws. So if those are the parts you think your missing then your right |
04-22-2007, 09:04 PM | #11 |
| More than likely...that is if they left it alone as it came from Traxxas. There's always a slipper on the Traxxas stuff to keep you from breaking everything. |
04-22-2007, 09:28 PM | #12 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
Do you have the tranny that's like this: http://www.traxxas.com/products/elec...ede-tranny.jpg If so it's the newer tranny with the slipper, just crank down on the nut to squash the spring. |
04-22-2007, 10:22 PM | #13 |
I run the slipper in my brushless 'Pede... and I also run the slipper in my scale rig, it's on there so I just run it.
04-22-2007, 11:08 PM | #14 | |
It is exactly like that, thanks for the help. | |
04-23-2007, 08:01 AM | #15 |
Rock Stacker Join Date: Feb 2007 Location: jacksonville
can you buy the whole tranny brand new or do you have to buy the parts and put it together? if so can someone list the parts needed to build one?
04-23-2007, 09:04 AM | #16 |
check the vendors here, they have complete ones. you build it.
04-23-2007, 09:57 AM | #17 | |
Also, would be a good idea if you've never built one before to go ahead and print these out too: http://www.traxxas.com/products/nitr...amp_tranny.pdf http://www.traxxas.com/products/elec...pede_trans.pdf | |
04-26-2007, 05:26 PM | #18 |
Rock Stacker Join Date: Mar 2007 Location: somewhere in a land far away
| aluminum idler gear
I got a rustler,and i put a lot of stress on the tranny and the idler gear stripped,i don't know if it will help but before you install it i think you should get the aluminum idler gear,then lock the main gear.
