02-25-2007, 09:43 AM | #1 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
| Has anybody tried this?
hey if this is in the wrong place then move it! but i was thinking has anybody ever tryed this for an rc http://www.difflock.com/buyersguide/...ar/index.shtml it looks really good with a whole lotta flex compared to standard leafs. So i posted this to get all your big engineering minds working just because it performs really well thanks EDIT i was talking about the leaf mounts btw Last edited by theshimonator; 02-25-2007 at 09:47 AM. |
02-25-2007, 10:19 AM | #2 |
Pebble Pounder Join Date: Oct 2006 Location: Enterprise
are you talking about the revolver shackles? they work awesome for flex. but the only concern that i have and have seen is strength for hardcore wheeling. i think they're meant for a little less extreme suff. Last edited by krawlinCJ; 02-25-2007 at 10:23 AM. |
02-25-2007, 10:37 AM | #3 |
no i was talking about the spring mounts and the revolver shackles i was thinking if there was anything made like that for rc but if not then for someone to make something like that.
02-25-2007, 10:39 AM | #4 |
ohhhhh. I got ya |
02-25-2007, 12:19 PM | #5 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
im going to try to make some for my self. it may take a while but ill try it
02-25-2007, 02:52 PM | #6 |
i've attempted six times and they get so fiddly, but if you do manage it post pics here and if yu sell 'em send me a set for free yer? |
02-25-2007, 03:08 PM | #7 |
The leaf hanger mount would be easy. Just use some small piano hinge and weld/braze the tabs to it. Or you could do the same thing they did and use some lengths of tubing to make the hinge and pass a cap screw through it and nut the other side. There's also the Z Boxes from Tera (same people that make the Revolvers) that are the same concept: |
02-26-2007, 10:30 AM | #8 |
Rock Stacker Join Date: Oct 2004
you could also make pivoting spring pads for the axle to achieve a similier effect. Using either method you will need something to locate the axle side to side as the leafs will now allow a good deal of movement. A telescoping A-arm would pobably be the best bet as it would follow the movement of the leafs more closely then a panhard. However if its on a non steering axle it may not be so terrable to warrent a locating link. |
02-26-2007, 10:47 AM | #9 |
Newbie Join Date: Feb 2007 Location: Mesa
| Orbit eyes springs
AOR offroad used to make leaf springs with spherical bearings in the ends for the same effect: http://www.off-road.com/toyota/aor/orbit/ |
