10-28-2020, 06:19 PM | #1 |
Newbie Join Date: Oct 2019 Location: Texas
| What bearings do you run in wet condition?
I have no experience with stainless steel bearings yet but read that they are corrosion resistant. Anyone run them in their RC car or truck in wet conditions? I'm aware that bushings are a good alternative but at higher speed they can wear out fast and put grooves on drive shafts and make everything sloppy. |
10-28-2020, 07:05 PM | #2 |
| Re: What bearings do you run in wet condition?
I have always ran factory sealed bearings.... The only time I find they rust is when I leave wet, muddy grass wrapped around the axle shaft, between the hex and the bearing. Otherwise never a problem.
10-30-2020, 11:03 AM | #3 |
The type of bearing is less important than proper maintenance after running in wet conditions. At a minimum you will need to run sealed bearings but even sealed bearings will require proper cleaning and lubrication on a regular schedule. A quick wash and dry then spray with WD40 will go a long way to extending bearing life.
11-01-2020, 03:33 PM | #4 |
Quarry Creeper Join Date: Dec 2016 Location: DA U.P.
Bushings have got a bad wrap... For crawlers I see not one difference and I prefer them for less maintenance. I run run on all exposed areas for sure and they last a lot longer Last edited by MAGNUMB; 11-07-2020 at 11:47 AM. |
11-01-2020, 09:13 PM | #5 |
RCC Addict Join Date: Jun 2008 Location: Mudville
Ball. BUHAHAHAHHAAHAHAHHA I tend to use Fast Eddy Bearings. Just need to be sure to use compressed air and blow out the bearings as good as you can. For crawlers. I gon't do much until I do maintenance or have to deal with a bearing... |
11-05-2020, 10:30 AM | #6 |
Newbie Join Date: Sep 2020 Location: ABQ
Tag-a-long question. Rubber or metal shielded bearings? It seems like rubber would be better to keep water out, but I've never had much luck with maintenance. Seems like once the rubber is out it will never go back in appropriately. Metal shielded would let more water in, but you can remove the shield and blow them out. Any thoughts / experience? |
11-05-2020, 12:48 PM | #7 |
RCC Addict Join Date: Aug 2020 Location: Jacksonville
My .02 for what it's worth... Bearings are too cheap and too easy to replace to lose sleep over. Run them ragged and pop new ones in. If you're having to do that often it just means you're having more fun than if the truck is sitting on a shelf. Now if we were talking a 1:1 truck and it involved a jack, puller, hammers, beer, friends, and cussing, yeah I'd be worried about what kind etc. |
11-05-2020, 02:46 PM | #8 | |
| Re: What bearings do you run in wet condition? Quote:
11-05-2020, 09:06 PM | #9 | |
Quarry Creeper Join Date: Dec 2019 Location: California
Yep I do the same, Fast Eddy makes plenty of bearing kits for most of the RCs out there. Although rubber sealed bearings packed with marine grease seems to be the most corrosion-resistant. | |
11-06-2020, 05:34 AM | #10 |
Quarry Creeper Join Date: Jan 2008 Location: Edmonton, AB
Rubber shielded bearings are a double edged sword. While they keep dirt intrusion at a minimum. Dirt will still get in and once it does it’s trapped. On a pure mud truck oilite bronze bushings are your best bet imo. Metal shielded bearings require more cleaning but can last longer when kept clean and with less rotational friction. Sent from my iPhone using Tapatalk |
11-11-2020, 07:48 AM | #11 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
bearings are pretty cheap. Replace them when needed.
11-11-2020, 08:07 AM | #12 |
When installing bearings I'll fill the cavity between them with grease so that the bearings are "packed" with grease when squeezed into place. This makes you realize two things. First, those rubber seals are not very good at actually sealing, and most rc bearings dont have hardly any lubricant in them from the factory. Yes, filling bearings with grease adds some negligible amount of drag. Not enough to notice IMO with our geared down overpowered toys. Another thing I do to my submarine trucks is drill holes in the axle and trans housing for a 3mm grub screw. This allows me to purge the water/grease out with a needle fitting on a grease gun. Yes this is a bit messy, as contaminated grease comes out from the external bearings, but once you see how much water comes out as well you'll be glad knowing that your gears and bearings aren't rusting away while it sits on the shelf and you'll be able to significantly extend the time between proper rebuilds/bearing replacement. I run Avid bearings in my fleet. They seem to hold up well for the price. I've never had luck pulling the seals out and having them reusable. They always seem to get knicked or distorted. |
11-12-2020, 07:45 AM | #13 |
Never though about putting grease zerks on a 1/10. Love it!
What bearings do you run in wet condition? - Similar Threads | ||||
Wet Proline dual stage foams.. still run them? | Mudsplat79 | Tires and Wheels | 4 | 12-04-2019 01:39 PM |
AXIAL WRAITH SPAWN - wet swamp run | waqr | Videos! | 1 | 07-29-2017 06:11 AM |
Wet Wraith Run | flascx10 | Videos! | 0 | 05-03-2013 09:01 AM |
Wet Run Care and stripped tranny screws | alexchen86 | Axial SCX-10 | 1 | 07-01-2010 04:17 PM |
Very wet long trail run... | caprinut | Scale Videos! | 2 | 10-27-2009 08:19 PM |
