01-02-2021, 06:26 PM | #1 |
Newbie Join Date: Jan 2020 Location: Fruitland Park
| Next Crawler Trx4 Bronco vs Axial Capra
So eventually i will buy both that being said i own a trx4 sport and my son is now into crawling (we are making a decent sized course on our property) I like both vehicles but am trying to plan my next purchase pros of trx4 : shares parts with sport and my son and i can share bodies and other stuff and we can trail and crawl in the state park behind our home.. looks amazingly like a real truck and making scale mods are fun pros of capra: my son thinks it looks cool and we could make more complicated obstacles for it to climb than our stock(ish) trx4 sport ..not sure of its trail and crawl abilities .. with the right upgrades like motor and esc servo its a great performer cons of trx4: i own a sport already.. its a little top heavy unless you spend money to offset with brass etc (have a bowhouse low cg battery tray already) servo and horn need to be replaced and probably eventually need s motor esc (considering 1800kv fusion setup) i dont bash just rail and crawl so slow speed control is more important ( ihave a rustler 4x4 brushless and 6s kraton for bashing) cons of the capra: different brand i dont know anything about axial parts or working on them .. im hearing the dig and regular servo die easily .. not many bodies available and not very scale realistic looking so like i said i will end up buying both but not sure which to buy first... flip a coin?? |
01-02-2021, 06:43 PM | #2 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: Next Crawler Trx4 Bronco vs Axial Capra
I have a TRX4 Bronco. I’ve never had an Axial vehicle. That being said, I personally would choose TRX4 over the Capra for multiple reasons. I don’t really care for that style, I’m more scale looks. The Bronco is great for scale needs lol. I think it just comes down to which you think you’ll have more fun with now, since you do plan on getting the other one later down the road. _________________ One lonely TRX4.... |
01-02-2021, 07:05 PM | #3 |
RCC Addict Join Date: Mar 2019 Location: Hemet
Honestly they’re not even in the same category. I’ve owned both, still own a stock Capra and a Capra built lcg truck. The Capra will out perform the trx out of the box all day long. The Capra is limited on battery size due to the compartment and it’s not the easiest to work on. But it’s really just a matter of picking what you want right now, which I would say the Bronco because you have the sport so you and your kid can drive similar lines n styles. But you won’t be disappointed with the Capra and who knows later on you can end up turning it into a scale truck on a lcg chassis. And fwiw I scabbed a stampede body on my Capra before I tore it apart to give it a more “scale” look mounted it on magnets Sent from my iPhone using Tapatalk |
01-02-2021, 07:16 PM | #4 |
That looks really good Fricker! That changes my mind on the Capra lol. _________________ One lonely TRX4.... |
01-03-2021, 07:30 AM | #5 |
Quarry Creeper Join Date: Dec 2013 Location: The Garden State, North of I-80
That body looks great on the Capra! Other than mounting on magnets and trimming the body properly, did you have to mod anything on the Capra? Do you have a link to that body? There are millions of Stampede bodies out there! (Currently finishing up a Capra kit build.) |
01-03-2021, 08:03 AM | #6 | |
RCC Addict Join Date: Aug 2020 Location: Jacksonville
| Re: Next Crawler Trx4 Bronco vs Axial Capra Quote:
01-03-2021, 09:02 AM | #7 |
The number phildirt listed is correct. I didn’t have to modify the Capra at all. Just did a whole lot of trimming on the body. I would have left the windows in it, had they been clear. But I got the body from someone else already painted and they’d blacked out the windows. The back end is a tad short but it really didn’t rub too bad. There’s some action shots and hopefully you can see where I put the magnets in the last pic. Sent from my iPhone using Tapatalk |
01-03-2021, 11:28 AM | #8 |
Rock Stacker Join Date: Oct 2020 Location: San Jose
I have a dedicated crawler and a TRX-4. The crawler is a Power Racing Komodo Rocker, about 10+ years old. This was a mid range competition crawler at the time. It has crazy flex. The TRX-4 if the assembled kit and I added the sport body. That way I get the lockers and the 2-speed trans. I upgraded the tires (Pro-line Hyrax predictor compound) and wheels (Injora Bead locks). In the end the TRX-4 is faster, has a better turning radius, and climbs better. The dedicated crawler only helps in places that require extreme articulation or approach/departure angles. It also looks very graceful articulating over the rough stuff. This should help as well. https://youtu.be/C3MRJ9v75-U I went with the TRX-4 on this build because of the flexibility of the platform. |
01-03-2021, 01:33 PM | #9 | |
That is awesome that you can get a scale body like that on a Capra without much fiddling around. And the body doesn't cost a gazillion dollars to boot! Loving the fact that you can still keep the drivers and the kit light bar. Would these magnets work for the mounting? https://www.amainhobbies.com/xtra-sp...-59801/p961497 | |
01-03-2021, 02:32 PM | #10 |
Yea those would work for sure. I got some off eBay and used double sided tape Sent from my iPhone using Tapatalk |
01-03-2021, 03:38 PM | #11 |
I like that body and it’s cool to see someone not stressing out over wheelbase/fender arches...looks like a real project buggy. Good job
01-03-2021, 03:57 PM | #12 | |
Thanks, sometimes it pays to have junk... I mean stuff laying around lol I think I’ve seen a couple creep bodies on some Capra’s and they look good too Sent from my iPhone using Tapatalk | |
Next Crawler Trx4 Bronco vs Axial Capra - Similar Threads | ||||
Capra+Bronco Body= Bronco Truggy | FoxHatfield | Axial Capra | 7 | 01-27-2020 06:16 AM |
Backyard Crawler course update and TRX4 Bronco video | JMHZ2401 | Videos! | 0 | 07-07-2019 08:25 PM |
