Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: what to buy?
Old 02-15-2004, 10:58 AM   #1
Default what to buy?
I'm kinda into nitro but i want to get an electric crwler....... is the tamiya pajero any good? it's cheap and looks fun but is it any good?
if not i'll probobly get a txt1
bizoona is offline   Reply With Quote
Old 02-15-2004, 11:01 AM   #2
It's a setup!
jason's Avatar
Default Re: what to buy?
Depends what you want to do with it. The pajero is small scale and wouldn't do worth a crap for the kind of crawling I do.
Out of the box, I think the TXT-1 is the best bet. Also with very little x-tra cash it can be made VERY capable.
Did you read this article?
http://www.rccrawler.com/article2.ht...rder=0&thold=0
jason is offline   Reply With Quote
Old 02-15-2004, 11:09 AM   #3
no.... thanks
and what do you thonk of the clodbuster? any good?
Old 02-15-2004, 11:22 AM   #4
It's a setup!
jason's Avatar
I don't have any personal experience with them, but they seem to do well. Maybe someone else will chime in.
Old 02-15-2004, 03:06 PM   #5
Well Clods are horrible in stock form but wiuth something like the Gecko and some aluminum links, a Super Rooster, and some good motors it can be a very capable crawler. It would do as well as the TXT-1 would out of the box and it mybe slightly cheaper especially after you buy a ESC and some motors fpr the TXT-1. I would think that either one is a good choice it just depends on how much work you want to do yourself. If yuo have any questions just ask.
jugg_crawler
jugg_crawler is offline   Reply With Quote
Old 02-15-2004, 03:29 PM   #6
Highmark's Avatar
It all depends on the type of crawling you plan to do, if you have itty bitty rocks a pajero with locked diffs would do great-and you can add larger wheels and tires later as you get better. A pajero is also considerably less costly then a TXT-1. But as Jason said if you want to do the big stuff a TXT-1 is about as good as it gets for a factory crawler. Clods are good but the stock chassie is horrible-for $160 you can get a nice gecko set-up from Rcguy and have someone like Dev2K from RCMT fab you a stearing set-up. Another consideration is the TLT-1 which is simmiler to a smaller version of the TXT-1. It costs less and with a few mods would probably crawl very well. Also cheak all the tech articals on the site!
Highmark is offline   Reply With Quote
Old 02-16-2004, 07:06 AM   #7
i'm looking for spmething like the bruiser but cheaper...
i mean not a monster truck but somw kind of craweling truck... i thought of putting smaller wheels on the clod buster if it's [ossible
Old 02-16-2004, 11:01 AM   #8
You could put smaller tires on a clod, but it isn't good for crawling you want a tall tire.
MaxxZilla is offline   Reply With Quote
