03-05-2007, 09:33 PM | #1 |
Newbie Join Date: Feb 2007 Location: so cal
| axle problems
ok so i doubled up my gears and found that the pin that goes throught the axle and gear case housing sheered rite off i have since tried to use a codder pin, rivet, and tension pin they have all failed to hold up also.. is anyone else having trouble with this? if so how can i fix it? any info or input will help... thanks
03-05-2007, 11:04 PM | #2 |
Quarry Creeper Join Date: Mar 2006 Location: Gresham
are u talking about the axel shaft or the rod that goes through the gears for high and low or somthing else |
03-05-2007, 11:45 PM | #3 |
Pebble Pounder Join Date: Oct 2005 Location: Yorktown Virginia
best fix for that is to get an allen wrench key and cut it to size since it is hardened steel. But... remember that beefing up that section will only cause another thing to be the weaker link (plastic coupled if you have it, planitary gears, axle where the pin goes through...etc) stop binding it up and dont be afraid to pick it up and reposition it...i used to bind mine up and try to drive through a tough obstacle, but learned quick, heh. good luck, hope this helps! |
03-06-2007, 09:31 AM | #4 |
it is the pin that goes through the axle shaft. i will try the allen key thanks for the help let you guys know how it works...
03-06-2007, 01:19 PM | #5 |
i just broke the pin that goes through the end of the axel climbing my couch i should have never cut my front tires:smile:
03-06-2007, 01:38 PM | #6 |
once the moding starts you start to break... oh well its all apart of the fun
03-06-2007, 04:03 PM | #7 |
i just put another piece of medal in place from a staple gun,tryed a cotter key that just raped around my axel |
03-06-2007, 04:49 PM | #8 |
RC Kid... read my post above. you cant use any type of metal, it has to be hardened steel or it will just bend. The sheer strength of regular metal is nowhere near as durable as the sheer strength of hardened steel.
03-06-2007, 05:25 PM | #9 | |
i just cut a staple from a staple gun and it works good not a regular staple gun from like school like working on houses its an older one and i can bind my tires all i want and nothing happens | |
03-06-2007, 11:28 PM | #10 |
lets see how long that lasts eh? |
03-06-2007, 11:32 PM | #11 |
its only a temparery fix cause i cant start cuting my dads tools up and puting them on my rccar then i would rather have three wheel drive over having 4 wheel drive |
03-07-2007, 09:57 AM | #12 |
Rock Crawler Join Date: Mar 2006 Location: Dayton
^^^ that's just funny. my dad generally doesn't like me cutting his tools up either. just go to walmart and get like a 5 dollar set and use it. -Dalton |
03-07-2007, 12:31 PM | #13 |
| go to the dollar tree and buy a cheap set. close enough and better than a damn staple |
03-07-2007, 02:03 PM | #14 |
that maybe true but i have to get down to the dollar tree
03-07-2007, 04:33 PM | #15 |
Pebble Pounder Join Date: Dec 2006 Location: wood lands of no were to important
i use to have this problem to. i bought a metal drill bit the exact diameter of the hole in the axle. thin a cut the bit to fit in place. works great for me havin broke it yet. and ive been runnin it for around 5 months now. hope that helps any. |
03-07-2007, 05:03 PM | #16 |
ill try ur idea sense my dad breaks drill bits all the time he should have some around that are broke thatl fit
03-07-2007, 06:32 PM | #17 |
i used the allen key and man it works well i tested it till the battery died... thx for the help.. now lets see what will break next?
03-07-2007, 06:36 PM | #18 |
on the older nylints do the engines have more power than newer ones
03-07-2007, 07:48 PM | #19 |
i assume you're inquiring about the motors? i don't think think so, the older gens did have tighter belts and stronger (i think) planetary gears though. -Dalton |
03-07-2007, 10:13 PM | #20 |
cause i have a gen 1 or gen 2 and i have a course in my back yard and i can go through it in high,my one that the steering motor went out on couldnt even make it through the entrence and the drive train is in the 1 i rebuilt
