03-06-2007, 08:22 PM | #1 |
Newbie Join Date: Mar 2006 Location: N.ZER in Auzzy
| Drive Shafts Question
Hi there, Can anyone help with this Q, im looking but cant find any Traxxis Long Shafts, Ive seen them but do you think i can find them again, No. There for a Stampede Gearbox and my T.L.T , I want to place my links mounts behind the axles but the shafts that came standed are not quite long enough. Any help or links would be much app. Cheers fellow Crawlers |
03-06-2007, 08:24 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
you'll have to splice a couple together and make your own extended shaft.
03-06-2007, 08:28 PM | #3 | |
Quarry Creeper Join Date: Nov 2006 Location: Rats nest Grafton ND
One thing I have seen done is people using two internal (male shafts) and one external (female) shaft. They cut the female shaft then slide it onto one of the male shafts then but everything together to get proper placement then CA the sleeve to one of the male shafts. | |
03-06-2007, 08:31 PM | #4 | |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
03-06-2007, 08:50 PM | #5 |
Cheers for the fast responce guys, hitting the hobbie shop now. will just try to join some together. Thanks. |
03-06-2007, 08:50 PM | #6 |
| http://www.orcrc.com/tltbuildup.htm Take a peak at this build up using two female Jato shafts. Same principle as I posted earlier just using two female shafts rather then two male shafts. |
03-08-2007, 08:47 PM | #7 |
Thanks Rat 1, very helpfull indeed. helps having a pics to go off.
