04-25-2007, 08:11 AM | #1 |
Quarry Creeper Join Date: Oct 2006 Location: Great White North!
| Delrin links.. .
I picked up some 1/4" delrin rod... Gonna try making some links out of it.. but I would like to do the bent links.. Whats the easiest way to bend delrin and get the links the same?
04-25-2007, 12:03 PM | #2 |
Pebble Pounder Join Date: Mar 2007 Location: creepin through the gates!
where did you get your links, did you order them or get them local, I have a link to order but I didnt know if maybe plastic shops might carry delrin.
04-25-2007, 12:16 PM | #3 |
Pebble Pounder Join Date: Jan 2007 Location: Gresham
I have been wanting make some myself (I would buy but I like to make things myself) how do you guys get the ball ends onto it, do you shave down then end then thread it? Thanks and sorry for the noob question. TQ |
04-25-2007, 12:53 PM | #4 |
Just a guess here but I would say that you drill and tap a hole in the delrin just like you would if you were using alluminum rod and thread in 8/832 alltread and I like to use revo big rod ends they are bigger and stronger than the tmaxx, you have to tap the rod ends aswell.
04-25-2007, 01:20 PM | #5 |
Rock Crawler Join Date: Sep 2004 Location: Santa Rosa
The easiest way I have found to bend delrin is to use the base for a carpenters square (theones with the sliding rule and level), clamp the rod to the long flat side, heat up the other end and clamp it to the 45* side with some small clamps. Let it cool and move on to the next one. Like Twisted mentioned, drill and tap like you would aluminum, unless you have a lathe and want to get fancy. Last edited by gone_wheelin; 04-25-2007 at 01:21 PM. Reason: Damn typos! |
04-25-2007, 01:26 PM | #6 |
RCC Addict Join Date: Sep 2005 Location: Behind the torch!
I drill and tap mine and I use set screws instead of allthread. Another thing if your are going to bend them for high clearance, heat them very slowly as you bend them. Once you have the desired angle hold it in place while it cools. Delrin likes to keep it's shape |
04-25-2007, 01:48 PM | #7 |
This works on solid aluminum very well, and you may also be able to use it on the delrin. You could use a die on the end of the link material vs. tapping into the end. This would give you a male thread right on the end of the link that you could thread the rod end right on to. Wouldn't be quite as strong at the thread area if using delrin, but if you used 8-32 thread sized rod ends, you'd end up still retaining most of the thickness at the threaded portion. That's just another way to do it....but I would recommend tapping it and using all-thread, grub screws, or even socket cap hardware and then just cut the head off. |
04-26-2007, 06:29 AM | #8 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Drilling and tapping internal threads in the Delrin would be far stronger than using a die to cut external threads...
04-26-2007, 08:34 AM | #9 |
Quarry Creeper Join Date: Mar 2006 Location: Juneau Alaska
One thing that I use when I work with Derlin, Plexi glass and plastics in general is thread inserts. They hold realy good and I dont have to worry about pulling the threads out of the stuff I am working on. I get mine at my LHS (Local Hardware Store). Depending on what I am working with I use the plasic inserst and other time I use the self tapping wood inserts. |
04-26-2007, 09:20 AM | #10 |
Do they make those threaded inserts small enough for this application? Which one would you recomend?
04-26-2007, 11:45 AM | #11 | |
04-26-2007, 11:49 AM | #12 |
Thanks for the info, I was just at the hardware store yesterday, damn now I have to go back again (the wife dreads me going there) lets see what else I can find, lol.
04-26-2007, 12:24 PM | #13 |
It's really not necessary to put inserts in, the delrin holds threads just fine, I bend and break 4mm screws before the threads give out.
04-26-2007, 01:46 PM | #14 |
Rock Crawler Join Date: Apr 2006 Location: pasco,Wa
04-26-2007, 05:24 PM | #15 |
Rock Crawler Join Date: Apr 2004 Location: toolsa, jokelahoma
04-30-2007, 02:36 AM | #16 |
Rock Crawler Join Date: Jan 2007 Location: Do I look like a freaking people person?
Maybe i missed it......where do you get delrin?
04-30-2007, 08:07 AM | #17 |
This is where I get all my plastics: http://www.usplastic.com/catalog/cat...ookie%5Ftest=1 |
04-30-2007, 08:39 AM | #18 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
The way I did it very successfully was with: 1 Pot boiling water 1 pot Ice water Heat resistant Gloves Prebent Aluminum template Wear gloves, dip delrin link in boiling water until soft, lift out and bend to match template, dip in ice water til cool. done. Done it with a torch and ice water previously too. Worked well if you are careful not to blister the delrin while heating. |
04-30-2007, 09:06 AM | #19 |
Adilynsdad too! Join Date: May 2004 Location: G ville
I've used inserts on polyethelyne before. I put the insert on my soldering iron tip and pushed it where I wanted it. Not sure if it would work on delrin.
