04-25-2007, 04:20 PM | #1 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
| what do i need to use 2.2 wheels on my 1/18 nylint
like the title says what do i need if anything do i need to use 2.2 size wheels
04-25-2007, 05:02 PM | #2 |
Pebble Pounder Join Date: Sep 2006 Location: everson
you need to use a 2.2 wheel with a 7mm hex. the only ones i can find is the ones on wal*mart toys. i have looked and looked and cant find anyone who makes a 2.2 wheel with a 7mm hex. |
05-04-2007, 06:35 AM | #3 |
can anybody help me???
05-06-2007, 05:43 PM | #4 |
Quarry Creeper Join Date: Jan 2006 Location: Wales
the simplest way to mount 2.2 wheels to a nylint is to epoxy the gray part (the inside) of the stock wheel into the inside of the 2.2 wheel the hardest part is to make sure that the whole assembly is straight but once it's done it's rock solid.. hope this helps..
05-07-2007, 08:38 PM | #5 |
Pebble Pounder Join Date: Feb 2007 Location: sunman
hey mike, forgot to tell ya, i got some 1/4" drive adapters about 3" long that will slide over your hex on the nylint, then you can heat up the other end and melt through a regular size hex for your 2.2's then jb it a lil and your done. it sounds nig rigged but someone on here did it and had good luck. search around , and if u want pm me and i'll send them out to ya for a couple bucks,
05-09-2007, 04:27 PM | #6 |
ok cool thanks
