04-28-2007, 06:21 PM | #1 |
| How To:Locking The Pede...NO Gooo
I have seen this on RCC somewhere already, but there are always people asking how to lock the Stampede tranny, so I thought I would add another search hit to the site, and also have some pretty good pics to really show it well. There are ways of course to do it with a goo substance such as JB Weld, Plastisteel, hot glue, epoxies, etc...but this is how to do it without using any goo at all which leaves you with no mess if for some reason you do decide to go back to having a "differential" tranny. For reference, when talking about the pede tranny, the main shaft assembly (the part that runs through the tranny to each drive shaft to the axles), is called the differential assembly. The large white gear on this main shaft is called simply the differential gear. The planetary gears are the four identical cylinder shaped gears that install inside the differential gear. The two sun gears are the gears in which the planetaries rotate around...hmmm go figure ...these gears are the one's that exit through the case to the drive shafts. What makes the pede have a "differential" action...meaning you can hold one shaft and the other will still turn...is that the two sun gears are never BOTH in contact with all four of the planetary gears at the same time. Only two of the planetaries are in contact with each sun gear. In this way of locking the tranny, you are simply putting all four of the planetaries in contact with the sun gears all the time. Now on to the pics and steps.....don't worry, it's very simple. --First pic shows the planetary gears installed into the differential gear in it's stock configuration. --Second pic shows one of the planetary gears removed (the one that sits lowest in the differential), and a 3mm nut put over the shaft and resting on the bottom. --Third pic shows the planetary reinstalled on top of the 3mm nut spacer. --Fourth pic shows the only modification you have to do...the "cap" of the differential gear housing has four "donut" shaped holes on it to locate the shafts of the planetary gears when you've screwed it down. The two "donuts" that are the tallest now need to be shaved down a bit (the same bit as the thickness of the spacer you installed). That's it! You have to do the spacer steps to a total of TWO planetaries...the two opposite of each other. Now put the cap on the differential gear with the four screws and you have a locked Stampede tranny for your crawler. NOW GO CRAWLIN' Last edited by Offroader5; 04-28-2007 at 06:24 PM. |
05-01-2007, 04:33 AM | #2 |
Rock Crawler Join Date: Jan 2007 Location: Long Island NY
killer idea just the amount of weight saved also saves a lot of time to.. waiting hours for jb to dry plus you dont have to buy more snot to lock the trans up i wonder how many ounces this mod would knock off of the center mass rotation |
05-10-2007, 08:15 PM | #3 |
Newbie Join Date: Apr 2007 Location: Midd.
Works like a charm.
05-10-2007, 08:37 PM | #4 |
Rock Stacker Join Date: Sep 2006 Location: East Valley
If you need a quick fix I've heard of people putting foil in the diff.
09-22-2007, 02:44 AM | #5 |
Newbie Join Date: Jul 2007 Location: queensland australia
thats a f*#@!^g awsome idea thanks mate i appreiciate it alot |
09-22-2007, 05:31 AM | #6 |
Quarry Creeper Join Date: Nov 2005 Location: Raleigh
i actually just did this yesterday and just drilled out a 4-40 nut and so far so good, thanks for the easy tips
09-23-2007, 01:13 AM | #7 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Other then JB, I have seen quite a few other goo methods fail, but never this one. Axles, shafts, and pinoins, but this one alsways has held true for me. Nice write up |
09-24-2007, 10:34 PM | #8 |
Newbie Join Date: May 2006 Location: Granite Falls
when I did mine, I just used a couple washers from my TLT kit, and it worked great:thumbsup:
09-25-2007, 08:57 AM | #9 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
I used a method similar to this.... It failed on me after a few months of use. I ended up doing a trail fix and used a super glue and sand mix to lock it. I didn't have any other way of fixing it at the park, and its held up ever since |
09-25-2007, 09:13 AM | #10 |
I added a link to this in the tips, cheap tricks sticky. |
09-29-2007, 01:25 PM | #11 |
Rock Stacker Join Date: Sep 2006 Location: ITALY
many thanks, but i found a better solution.. u must use the servo rubber!!!!!!!!!!! and no modification to diff!!!!! |
10-23-2007, 11:30 AM | #12 |
Rock Crawler Join Date: Aug 2006 Location: Pinedale, WY
nevermind i figured it out Last edited by dezrik; 10-23-2007 at 11:35 AM. |
04-13-2008, 05:08 PM | #13 |
Pebble Pounder Join Date: Feb 2007 Location: canada
that worked awsome nice and easy. -Wes
