06-07-2007, 09:18 AM | #1 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
| DROOP? droop suspension?
When in the heck did DROOP become a suspension style? Droop is defined as the amount of down travel the suspension system has. All suspension style have droop. there are about 10 threads out there that are calling internal springs shocks as droop style suspension, what is that all about. All this is accomplishing is making it more work to teach newbs what the facts actually are. Is it me or are others confused these days? LOL |
06-07-2007, 09:24 AM | #2 |
Feeling prolific this morning?
06-07-2007, 09:27 AM | #3 |
RCC Addict Join Date: May 2005 Location: I live Here
i think i was the one that did the the final drop of water in the glass that spilled. so what do you call a suspension with a shock with no external spring with on one small on inside that the shock travels more down than up, there are some with 50% 50% ? ? ? ? |
06-07-2007, 09:28 AM | #4 |
Enlighten me please ,i think they are talking about full droop suspension, seriously i need to know so i can apply terms correctly |
06-07-2007, 09:28 AM | #5 |
| Sorry boss.............LOL just need to vent a bit.......I keep getting emails and PM's from newbs all confused about suspension lingo being tossed around. Heck the amount of misinformation being slung here these days has me confused maybe time for me to write a suspension lingo article LOL |
06-07-2007, 09:33 AM | #6 | |
I'm sure at some point in the near future, I too will try a droop "style" suspension set up to see for myself. | |
06-07-2007, 09:33 AM | #7 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
ive thought of a droop suspension being no springs. the rig is resting on the axles or bumpstops at idle and when crawling the axle has no where to go but droop. i guess shocks are needed to control wheel hop during wheel speed although when i try my drooper it'll be no shocks.
06-07-2007, 09:35 AM | #8 |
| Not all suspension styles have droop. Most crawler suspensions have been set up as 100% compression. You know, the coilovers running fully extended at ride height. How do those have droop?
06-07-2007, 09:36 AM | #9 |
You haven't tried one yet dez? you are always ahead of me of the stuff i try, and now i'am working on a full droop suspension for and oncoming build, i have beat you this time .....hopefully it works, if not i will pm you for help |
06-07-2007, 09:37 AM | #10 | ||
DROOP IS DROOP. From RCTEK: Suspension Droop: Quote:
All suspensions have droop. no suspensions are droop style For crawling droop is s 2 edged sword too much and it makes the rig unstable while on off camber situations, and get stuck in deep holes that rigs with less droop can ride over. that being said a vehicle with more droop is more stable on down hill decents that have off camber ledges. Im among those who feel you cant have too much uptravel and limit my droop to around 3/4" max | ||
06-07-2007, 09:38 AM | #11 |
RCC Addict Join Date: Jul 2006 Location: So Cal USA
This is good reading, tought I'd throw it in here... Droop Vs. others Enjoy, very educating... ~John |
06-07-2007, 09:41 AM | #12 | |
Droop can also be forced via uptravel of the opposite wheel on a solid axle. My current setup is fully extended shocks at about a 45% angle. the droop is about 1/4" from rest and the forced is about 3/8" | |
06-07-2007, 09:41 AM | #13 | |
06-07-2007, 09:43 AM | #14 | |
Haven't seen the need Carlos, I have been doing well w/ my torsion rig. I have enough parts kicking around to build one and I'm sure curiosity will get the best of me. In the terrain I regularly crawl, center chassis clearance is of prime importance and the Stick/Pimp Cane designs are perfectly suited to my needs. I have to admit that JIA's droop rig is far and away my favorite rig in the droop arena! | |
06-07-2007, 09:43 AM | #15 |
Newbie Join Date: Apr 2007 Location: NEWPORT NEWS
Same types of questions and answers that we ask in the 1:1 arena. I have a buddy who runs his Jeep on coilovers that are almost fully extended at static ride height. While I, on the other hand, set my coilovers up with only 3" of shaft stickout. The rest is droop. I only left a little stickout to prevent beating my kidneys to death on small bumps. I recently built a TXT based tuber with the shocks setup at full compression at static ride height. Instead of using internal springs to push up on the shaft (keeping it retracted), I just used a center tension springs from the frame to the axle to pull up on the axle... keeping the suspension in tension to help combat unloading. I guess a "droop" suspension would be described as thorsteenster said... built on the bumpstops, riding at full compression and only allowing droop as the rig goes over obstacles. In reality, it's just a coilover link suspension with no, or even negative spring rates.
06-07-2007, 09:44 AM | #16 |
I never said it was a style, but what does full droop mean though? is it even a correct term? i would assume it means suspension set at full compression when idle , and suspension moving 100% of the shock lenght or travel when at full droop?
06-07-2007, 09:46 AM | #17 | |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
Droop is just a term used to describe a suspension with no up travel. What is so hard to understand? I suggest you read the thread Krawler4life posted. | |
06-07-2007, 09:47 AM | #18 | ||
You are talking about the tire moving downward due to the axle twisting during articulation. The tire moving down is not the same as the suspension moving down. | ||
06-07-2007, 09:47 AM | #19 | |
06-07-2007, 09:48 AM | #20 |
