03-30-2005, 04:49 PM | #1 |
Pebble Pounder Join Date: Nov 2004 Location: Lakewood,CA
| Gear Lube?
What kind of gear lube does everyone use? I ran out of the ceramic grease abd was thinking of using some 300k diff lock grease....
03-30-2005, 05:15 PM | #2 |
Pebble Pounder Join Date: Aug 2004 Location: orange county n.y. , building the hydro crawler
Anything works well in a crawler, from wheel bearing grease to auto gear oil ive used basically evertything and it works fine.
03-30-2005, 06:12 PM | #3 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
not sure, i usually take out the check plug and add in some 85 weight oil i just run your basic grease like for ball joints and crap in mine.. i just lightly cover the gears and go. never had a problem with mine |
03-30-2005, 06:25 PM | #4 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
I use wheel bearing grease for 1:1's and some cutting fluid. They both work well.
