07-05-2007, 07:41 PM | #1 |
I joined the Band! Join Date: Nov 2006 Location: Sierra Vista, Arizona
| Crawlin on the beach front??
Any precautions? Please read-- I am going to go to San Diego soon (Del Mar area). Last time I went, there was this really neat rock on the beach. It was right up against this 15 foot cliff. This rock was so huge, must have gone down the beech for some 600 feet. And this rock has all kinds of ups, downs, crevaces, puddles of sea water, sand, and it was just like all over the place, but it was one big rock. Now I have never driven an RC on the beach before. But when I go again, I want to drive my crawler on this rock. Any precautions I should take to prevent rust, or something to prevent messin up my motors and axles? If there is some things I should worry about and somethings I can do to help prevent anything bad happening to my crawler, please, tell me. Thanks Last edited by Crawlerdude75; 07-05-2007 at 08:00 PM. |
07-05-2007, 09:09 PM | #2 |
RCC Addict Join Date: Sep 2005 Location: Behind the torch!
Beware off salt water. It will corrode stuff very fast. Last time I drove an R/C on the beach it was a brushless xxx-t. Very fun in the sand, but when I got home all my hardware was rusted and soon after my diff went. I didn't even get it in the water just wet sand. Have fun but be carefull. You might want to get a small air compressor to blow your truck out also. |
07-05-2007, 10:09 PM | #3 |
Rock Crawler Join Date: Aug 2004 Location: Saugus
Took my scaler to Ventura beach about a month ago, played in the sand and then on the rocks. Then since it was all sandy and it's completely waterproof, I gave it a shower before I left. Before: After: Yay! |
07-05-2007, 10:18 PM | #4 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Talk to the florida guys they know this all too well. I made a visit to them in florida at the beach and kicked up some sand with my rear dig. The tuber started to rust on the drive home. If I wouldn't have gotten paint back on it it would be looking a bit rough now. |
07-06-2007, 01:07 PM | #5 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
This thread is worth bumping for the pictures alone. |
07-07-2007, 10:01 AM | #6 |
Camel RC, you said you gave it a shower..... wouldnt more water make it want to rust even more? I was thinking a high pressure air compressor and use a blow nozzle, and hit it with big blasts of air. Maybe not. What ever works best I guess. for me though, when I crawl in the mud at my house, I leave my crawler out in the sun to dry the mud, then I blow it off with an air spray nozzle on my compressor. It works pretty good, but in your case (and mine upcoming) maybe water works better? Maybe dry it with an air compressor?
07-07-2007, 03:02 PM | #7 |
RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
07-07-2007, 03:08 PM | #8 |
Aluminum will corode just like steel.
07-08-2007, 01:40 PM | #9 |
Newbie Join Date: Jan 2007 Location: Orange City
Pack everything you can w/ grease, either replace bearings w/ bushings or plan on replacing them(bearings) after, and hose everything off w/ fresh water afterwards then re-lube. I dont run mine at the beach, but I know guys that run nitro when they can get away w/ it.
07-08-2007, 01:53 PM | #10 | |
Quarry Creeper Join Date: Jan 2005 Location: Westchester
07-08-2007, 10:04 PM | #11 |
Rock Crawler Join Date: Jan 2007 Location: Do I look like a freaking people person?
I don't have the problem with salt water here in Michigan.......BUT I would assume it would be similer to driving in snow. In your case spray it off with clean water then spray off the excess with an air compressor. Finally spray it down with WD-40 and wipe off the excess. |
07-09-2007, 05:06 AM | #12 |
Pebble Pounder Join Date: Feb 2007 Location: St.Marys County, MD
I almost lost my first rig at Myrtle beach last year, Just don't drive it into the waves on the beach. Remember wd-40 is your friend.
07-09-2007, 09:42 AM | #13 |
Quarry Creeper Join Date: May 2006 Location: Oregon
WD40 is your best friend when displacing water and preventing rust in these situations.
07-10-2007, 09:43 AM | #14 |
Rock Stacker Join Date: Feb 2007 Location: jacksonville
i live at the beach in jax. fl. it takes les than an hour for salt water to start rusting screws and such. wd40 would deffinatly help to spray as soon as your done, and leave it on till you can get home and take whatever you need apart and then clean with fresh water then spray with a compressor. i have had a few of my first nitro trucks rust up bad on me, locked up the bearings in the wheels and such
01-02-2008, 04:00 PM | #15 |
Newbie Join Date: Dec 2007 Location: camarillo, CA
01-02-2008, 04:34 PM | #16 |
01-02-2008, 04:44 PM | #17 |
you right. it is a formula. but when they were making it, it was test and it took them 40 time to get the right formula.
01-02-2008, 04:55 PM | #18 |
Newbie Join Date: Oct 2006 Location: Cincinnati
Has any one tried Fluid Flim, 100x's better than WD-40.
01-02-2008, 05:28 PM | #19 |
Pebble Pounder Join Date: Feb 2007 Location: Gloucester
WD-40 , or what ever you like , first . when done mild soap/h2o bath . then soak a rag in wd-40 .... and wipe every thing down . spray into bearings , joints etc. anything gritty after this needs to come apart , air blow down optional , suggested if available . I ran my sand scorcher at Va.Beach all the time with less care and never had major issues with corrosion or wear . Fluid film is more of a lubricant like sewing machine oil , and I'm reading on the tube that it prevents corrosion . WD-40 is a water dissipator , moves water away , the salt still needs to be removed to stop corrosion . Last edited by Frank3; 01-02-2008 at 05:43 PM. |
01-31-2009, 04:56 PM | #20 |
Newbie Join Date: Jan 2009 Location: townsend
If you rinse your rig off with water don't use a forceful spray it just pushes the salt in to every ware. They recommend you just let the water run over saltwater fishing reel so you don't force the salt into your reel. This is what i do to my reels and my 1/8 buggy. shortly after i take it apart and wd 40 it. just make sure it's dry |
