07-19-2007, 03:36 AM | #1 |
Newbie Join Date: Jul 2007 Location: Left Coast
| Upper/Lower link positions
Hello all. I'm new to the forum, and RC crawlers in general (have owned countless touring cars and Buggyies/Truggies in the past though) but was inspired to build one after seeing my friend's bro's rig a couple weeks ago. After a couple days I installed the following; Traxxas 125mm lower links Traxxas T-Maxx drive shafts spaced upper links locked diffs Losi metal upper link pivot balls 45 turn motor Mugen rear toe links High Tec high torque servo That made the truck ten times as capable, but I soon found the weak link after trying to stick a five foot drop-off down to a 45 degree concrete slope. So I stripped the truck down to the essentials and picked up some 2mm aluminum plate for a new chassis. Before I start drilling though, I'd like to know the optimal distance (on the vertical plane) between the upper and lower link mounts so as to obtain the most available articulation. For example, say the lower link sits 2.5cm below the upper link on the axle, should the lower link also mount 2.5cm below the upper link on the chassis? Also, if it would factor into the equasion, my upper links are 20mm shorter than my lower links. Thanks in advance for any and all imput. Last edited by OriginalGTI; 07-19-2007 at 03:41 AM. |
07-19-2007, 03:44 AM | #2 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Best way to do it is to run the upper and lower links as parallel to each other as possible. This will cause the truck to be neutral in anti squat.
07-19-2007, 11:40 AM | #3 |
Cool. Thanks for the help.
07-19-2007, 01:12 PM | #4 |
Newbie Join Date: Jun 2007 Location: Sacramento
From the sticky at the top of the page "crawler tips and tricks" 4-Link 101? Check out the link to the peterson's 4 wheel four link article. |
07-19-2007, 07:30 PM | #5 |
Well that just about sums it up.
07-19-2007, 08:04 PM | #6 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
here is more info, with more detail Anti-squat link setup thread Anti Squat and Suspension Tech droopy vs. conventional suspension Droopy vs. conventional |
