07-25-2007, 10:35 PM | #1 |
Newbie Join Date: Aug 2006 Location: everson
| stage 2 on a more comp worthy set of pti axels
well finally had a day off so i started to work on making a stronger ring gear i finally decided to cut my tlt spool apart so i just had the ring gear left from there i realized that it wont fit in the pti axel houseing it is to large but i did find a way to make it fit (i dont own a lathe which would have been nice there) so i just chucked it up and the drill press and held a file to it untill i got it the same size or just a lil smaller the the plastic pti gear then i had to drill the holes in the tlt ring gear i used a 3/32" drill bit for this i lined up the holes from the pti gear and started to drill i will post pics up tomarrow just wanted to start the thread tonight i dont have pics of the whole process just the start and the finished product so if anyone wants to kno more about this pm me and i will send a better detailed explaintion of how this is all done
07-26-2007, 12:07 AM | #2 |
Rock Crawler Join Date: Apr 2005 Location: Upland
I was thinking of doing the same thing. I'd really like to see your results. I started looking for alternative ring gears as well. I think I might have a few leads. Also you might want to check out this website. https://sdp-si.com/eStore/Direct.asp?GroupID=271 I'm going to see if I can find a gear set that will match the PTI ones. I'll be sure to let everyone know if I find anything. |
07-26-2007, 01:34 AM | #3 |
Quarry Creeper Join Date: Jul 2006 Location: In a tree top with my chainsaw!!
I am going to bed now and when I wake up there better be pics and test results. If this is going to work, I need to know if I should buy stock pti parts or some, ughh, tlt parts. Glad some one is trying to find a better R&P for the goliath. |
07-26-2007, 08:45 AM | #4 |
welli said i would post up the pics i have here they are they arint great pics but i hope they get the point over on what they look like |
07-26-2007, 10:09 AM | #5 |
How much material did you remove from the outer circumference of the gear? And how does it mate up with the pinion?
07-26-2007, 02:18 PM | #6 |
Wow. If anything, I give you an "A+" for the effort!
07-26-2007, 08:11 PM | #7 |
as i said i removed from the tlt ring gear to make it the same size as the pti gear i dont kno the exact amount but if you have a pti gear then you will kno when it fits and for the 2nd question it fits a lil tight bc the tlt ring gear is thicker then the pti's but its not to tight that it will mess up the gear from that i am told and thanks k_b i try and i hope tihs will help many other ppl with the pti prob i have |
07-26-2007, 08:33 PM | #8 |
This is exactly what I was getting at in your other thread.
07-27-2007, 11:39 PM | #9 |
this is looking like a very worth while mod. Good work so far |
