04-13-2005, 06:08 PM | #1 |
Pebble Pounder Join Date: Apr 2005 Location: i'm not sure
| crawler project begins!!!!!!!!!!!!
I'm a newbie to this sport and I have started my first crawler. Specs: axles: custom t maxx (axles built around tmaxx diffs) motor: 1 550 titan motor Chassis: custom 3/16 solid steel music wire tires: swamp dogs suspension: traxxas revo shocks, rockers Tranny: custom Any suggestions? |
04-13-2005, 07:50 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Pick-up a lathe motor to replace the 550, they have more torque.
04-14-2005, 08:31 AM | #3 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
i dunno about the rockers, its probably a lot easier and better to just mount them like everyone else around here, but if you get it to work, go you!
04-14-2005, 08:48 AM | #4 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
I highly suggest ya ditch that Titan motor. it is intended for 14.4 volts.. running one Titan motor on one battery will only cause it to run at half speed.. get a lathe motor or a Magnetic mayham motor...lathes are better unless your gonna run a GD600 reduction unit also
04-14-2005, 09:39 AM | #5 |
Ok I quess I will look for a lathe motor. I haven't bought the titan yet.
04-14-2005, 01:04 PM | #6 |
how do you post pics!!!!!! |
04-14-2005, 01:16 PM | #7 | |
Star info: http://www.rccrawler.com/forum/annou...nouncementid=1 Or you can have someone to host it for you like www.imageshack.us. | |
04-14-2005, 06:17 PM | #8 |
what do you guys usally use for trannys? I think I might use a 1/16 brass plate with 72 and 8 tooth gears.
04-14-2005, 08:15 PM | #9 | |
Quarry Creeper Join Date: Jan 2005 Location: Carlisle, KY
http://upload.thefordmccord.com/ | |
04-14-2005, 09:54 PM | #10 |
I dunno about the rockers, its probably a lot easier and better to just mount them like everyone else around here, but if you get it to work, go you! ( this is what spookyseven said) I want the rockers there because it is something you don't see. And you won't bend your shocks if you roll it and hit a rock. Your right it MIGHT be easier to do it like everybody else, but I not like every body eles. Almost every thing in my crawler is going to be custom. |
04-15-2005, 03:14 PM | #11 |
I got my frame mig welded today. It looks kind of like RokToys. |
