09-05-2007, 10:58 AM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Steubenville
| Does anyone run a Y link radius arm?
Does anyone run a Y link radius arm set up, like the Jeep front end kits available aftermarket? |
09-05-2007, 11:34 AM | #2 |
Rock Crawler Join Date: Nov 2005 Location: Okinawa, Japan
I asked this question when I started into this and I have not seen it done yet. Something about a Drag link being needed to center the Axle
09-05-2007, 11:54 AM | #4 |
Drag links don't center axles, a drag link is a steering arm. You mean a track bar... aka pan hard. If a four link or three link doesn't require a track bar, why would a Y link radius arm? I think I'm gonna go with a Y link for sure. |
09-05-2007, 11:59 AM | #5 | |
Not 100% sure if that would work or not, I've never seen it done. | |
09-05-2007, 12:16 PM | #6 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
| that still would not work for triangulation to hold it stable it needs atleast 3 arms, tried it you will need to run a track bar and the ylink in scale form will limit articulation.
09-05-2007, 12:16 PM | #7 | |
That's what I ment. Sorry As for Guido... Did you change the link mounts in the front so that they were not right above each other? In a real Y-Link they are not that way. Here are pics of my old rig. When ever I had the Track bar disconnected, my front axle swung left and right quite a bit. Last edited by TJ_Shunk; 09-05-2007 at 12:23 PM. | |
09-05-2007, 02:16 PM | #8 |
You'll definitely need a track bar if your running a radius arm setup (which is really what those are). The upper links are sort of triangulated, but that is not going to keep the axle under the rig. Another downside to a radius arm, is it does limit articulation some due to each side (passenger & drivers) fighting against each other when one side goes up and the other doesn't. In the 1:1 world, people that run this kind of setup, will usually remove one of the upper links on one side (just for the trail) so that they won't fight each other....but they still have the track bar....or on a real radius arm like in the older Fords, they will run a wristed axle which means it rotates about it's centerline at the mounts. Are you confused yet? :-P |
09-05-2007, 02:24 PM | #9 | |
09-05-2007, 02:26 PM | #10 |
09-05-2007, 02:26 PM | #11 | |
The radius arms on Guido are supposed to be similar to the Cage or Duff arms. So no, I don't plan to make them like the Jeep arms. They flex plenty for a scaler. | |
09-05-2007, 02:30 PM | #12 | |
09-05-2007, 02:31 PM | #13 |
hmm, I guess I am a meathead. The Bronco's are in a strait line aren't they? As for the travel... I also got more then shown in those pictures. I just can't find any right off the bat. |
09-05-2007, 02:35 PM | #14 |
09-05-2007, 02:40 PM | #15 |
Grizz's Y link on the Bronco is reversed than the Jeep would be. The main links connect to the UCA mount in his design, and the Y short link connects to the bottom. This is inverted than the norm, but it does raise the main link up higher for better clearance. |
09-05-2007, 02:50 PM | #16 |
09-05-2007, 03:26 PM | #17 | |
I would be interested to see somebody make a Comp rig with a Y-Link though. I think it would be interesting. Quote:
I love that trail. French Creek is supposed to be narley this year. *Hijack off* Last edited by TJ_Shunk; 09-05-2007 at 03:29 PM. | |
09-05-2007, 03:31 PM | #18 | |
My line coming down is just to your left. EDIT: Or is it the same spot? :? Last edited by Grizzly4x4; 09-05-2007 at 03:36 PM. | |
09-05-2007, 03:35 PM | #19 |
yeah I missed the trip this year too :(
09-05-2007, 04:38 PM | #20 |
Hell guys my driveway is worse than that. We call that a highway in AZ LOL
