06-26-2004, 12:41 PM | #1 |
I wanna be Dave Join Date: Feb 2004 Location: on a Big Rock
| Cutting Carbon Fiber Rod
Any tips for cutting Carbon Fiber Rod |
06-26-2004, 01:49 PM | #2 |
Newbie Join Date: Jun 2004
| Re: Cutting Carbon Fiber Rod
never worked with rod, but let me say this, wear a mask whenever you work with rod, the dust is dangerous if you breath it in. and if you get any dust on your hands or arms, rinse it off first just turn on the water and put your arms under the water to risne off what you can, then use your hands to get off the rest. oh yeah, you're gonna go through more blades than you would with aluminum. |
06-26-2004, 04:21 PM | #3 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
I don't see why a hacksaw wouldn't work. As said before, always wear a mask and googles when working with cf. You might even want to wear a welder's mask over the mask so you don't get dust over your face.
06-26-2004, 04:46 PM | #4 |
cutting the rod won't be as bad as cutting sheet, thats a real pain. CF will dull your plades really fast...suprisingly fast. i cut to medium sized holes in 3mm CF..and it took me 3 blades.....to cut about 18 inches worth of hole perimeter.
06-26-2004, 09:25 PM | #5 | |
| Re: Cutting Carbon Fiber Rod Quote:
:EDIT: I was watching T.V. and thinking about stuff,as I do alot. My wife gets mad at me cuz I watch a movie with her but my mind is wondering about thinking of other things O'well,she'll get over it. Anyway,I've heard of guy's cutting their carbon arrows with a tube cutter. Ya know the kind you cut automotive brakeline and copper tube with. Just apply a little presure and go slow with it. Might give that a try also. Oh,btw,you got a PM. | |
06-27-2004, 05:55 AM | #6 |
Newbie Join Date: Mar 2004
I use it and cut quite a bit of it for my helicopters, and I've found that the best way (for me anyway ) is with a dremel running fast with an abrasive cut-off wheel. You can get a couple of grades of wheels, the coarse ones seem to hold up a bit longer though. As for dust, do what everyone says; wear a mask and goggles, at the very least. If you have a flex shaft dremel, you can also cut under water. I fill up the sink, hold the rod just under the surface and cut it there. You'll have to re-grease your handpiece afterwards, but the dust all stays in suspension, so you don't breathe any of it in. I also don't think it splinters and frays as bad this way, maybe because it stays cooler??? Wayne |
