06-28-2004, 10:06 PM | #1 |
Quarry Creeper Join Date: Jan 2004 Location: CSU, CO
| Update slop reduction successful Picture numbers go from left to right. Picture 1: Red is where gear can engage. Picture 2: Pieces that would be cut out of aluminum, plastic, or a similar material Picture 3: Yellow is what Picture 2 would be glued/attached to. Picture 4: Blue hatching is Picture 2 installed. Picture 5: Same as Picture 4 but the red once again represents where the gear can engage. This is my new plan for reducing the slop in an E-Maxx tranny. It is actually my sixth idea on reducing the gear engagement area. Once again any replies are welcome, just as long as they are constructive. |
06-28-2004, 11:00 PM | #2 |
Newbie Join Date: Jun 2004
| Re: Revised plan to reduce E-Maxx tranny slop
good idea, far cheaper than re-machining the gears. but as said by someone in another post...you'll have to be going alot slower, if not standing still, to shift gears.
06-29-2004, 05:28 AM | #3 | |
I wanna be Dave Join Date: Feb 2004 Location: on a Big Rock
| Re: Revised plan to reduce E-Maxx tranny slop Quote:
06-29-2004, 11:30 AM | #4 | |
06-29-2004, 02:40 PM | #5 |
i'd be really interested to see how you make a wider gear ratio between first and second. sounds like a good idea. that way you got low end torque and higher ratio for more speed!
06-30-2004, 10:15 PM | #6 |
I have not had the time to work on my X-TXT so I have not tried my gear slop theory. I have been thinking about how to widening the ratio and I don’t think it is going to happen. There is no room in the case to fit bigger gear and I don’t have the time to fool around with different gear pitches. Maybe when I finish summer school, read the two books I need to read for AP Language, do a 100+ entry dialectical journal, and write an essay .
07-03-2004, 11:14 PM | #7 |
| Re: Update slop reduction successful
My modified gear worked on my test bed. My test bed is E-Maxx tranny in vice and my shifting servo (HS-81MG “click for info") in another vice. The motor used is a Trinity P2K. I have no idea if it will work in an actual vehicle. When I get more money I will find out.
