06-29-2004, 04:33 PM | #1 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| need motor help as quick as possible( Lathe Motor 55t)
well i just got my Integy Lathe 55t motor. I will admit, i don't really know shit when it comes to any of these electric motors anyway, how do i know what to hook wires to?? there is like 6 different places i can connect wires and do i need those resistors or whatever?? i can take a pic of the motor if that would help??
06-29-2004, 05:07 PM | #2 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Re: need motor help as quick as possible
Sorry I do not know much about motor lathe's. Dumb question... Does it come with a instruction manual? |
06-29-2004, 06:49 PM | #3 |
nope, but i wish.... is there any certain way to figure out which part the wires go to?? like how do i figure out the red? the black?etc?? i would like to get this up and running, but maybe i should have thought about this beforehand damn noobies |
06-29-2004, 07:30 PM | #4 |
Rock Stacker Join Date: Mar 2004 Location: wasatch front
there is no difference between a lathe motor and a normal modified 540 can the two tabs with the screws in them screw into the can. instead of soldering your capacitors to the can you solder them to the tab on the screw. use three capacitors an solder on from+ to the can one from- to can and one from neg to positive i put all three on one side. to find out what side is pos look at the black end bell and there should be a + sign and that side is the positive side does this help?
06-29-2004, 07:45 PM | #5 |
yeah but this thing has 4 screws.....2 with tabs only and 2 that have ground wires or something connected to those..i looked at the end and only see a + and it's off to the side( nowhere near either of the 2 screws w/ tabs only) i guess im just too much of a newbie and need to stick with more simple stuff owell, gotta get away from nitro someday here is a few pics of the end of it |
06-29-2004, 09:02 PM | #6 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
Here's how mine's is hooked up |
06-29-2004, 10:14 PM | #7 |
Rock Stacker Join Date: Jun 2004 Location: Hillsboro, OR
AdamF is correct. Basically all you have to do is look at the endbell. There is a + sign on it, place your positive lead there and your negative lead on the other side. You need to use the wide flat tabs to solder onto. Make sure you use the tabs that are seperated by the black plastic. The + and - leads shouldn't be on the same side 8O BTW, the Integy is an excellent crawling motor |
06-29-2004, 10:38 PM | #8 |
Newbie Join Date: Jun 2004
| Re: need motor help as quick as possible http://www2.towerhobbies.com/cgi-bin...?&I=LXJY37&P=7 here are some capacitors. you don't need to use them, the motor will still function without them... but these will reduce radio noise, which will reduce glitching. here's two ways to hook up the capacitors. some companies run only one (the one that goes from pole to pole) but the grounds to the can can't hurt. you can run either style, but for the one that goes directly to the can you'll have to remove part of the label and scuff the can. but i'm assuming that the metal screw is threaded directly to the metal can. and this is how you wire it up. i circled that little plus sign on the endbell. thats how you know its the positive side. BUT if you remove the endbell and put it back upside down (180 degree rotation from how it is stock) you'll get a reverse rotation motor. |
06-30-2004, 04:26 AM | #9 |
cool deal, appreciate it guys.. now that i look at your guys' artwork and see how its wired up, it just looks like common sense, but i don't have any of that anymore i'll try and get it wired up tonight after work Thanks again |
06-30-2004, 08:18 AM | #10 |
git-r-done |
06-30-2004, 08:45 AM | #11 |
Rock Stacker Join Date: May 2004 Location: Monroe
Noob! |
06-30-2004, 11:25 AM | #12 |
LMAO! Those pictures look like John Madden got ahold of them! |
06-30-2004, 12:19 PM | #13 | |
| Re: need motor help as quick as possible Quote:
i'll also remember that when you leave your Emaxx with me when you go outta town this weekend | |
06-30-2004, 12:20 PM | #14 | |
LMAO good one | |
06-30-2004, 02:59 PM | #15 |
the voices in my head made me do it! |
06-30-2004, 03:12 PM | #16 |
Quarry Creeper Join Date: May 2004 Location: Boobslando, florida
have you ran your new motor yet? how you like it?
06-30-2004, 04:51 PM | #17 |
some people gotta woprk and havent had time yet j/k getting ready to go outside now and wire it up and run it..so i'll be back in a while |
06-30-2004, 08:44 PM | #18 |
well, i just got in....only ran it for a bit but it did pretty good. im still not sure if i like it yet or not. it will take some more playing around with..its slow and crawls great, but it seems the motor doesn't have enough RPM's to bump up over stuff. also, if it gets into a pretty good bind( tire in deep hole) it will stall the motor. i need to play around with the gearing until im satisfied. but one good thing about not having enough RPMs to spin the hell outta the tires is that i really don't see me breaking anything again due to all the torque that's a +, specially since the truck is for my 8yr old throttle happy son but like i said, i just need to play with the gearing some more and see how it does then. it just started getting to dark to actually see what was going on |
